02-09-2022 11:50 AM
Hello all,
I am working on an ISR 4331/K9 router with a NIM-LTEA-EA module (so the "advanced" 4G NIM module), and I am trying to follow the ISR 4000 series Cisco 4G LTE and Cisco 4G LTE-Advanced Network Interface Module Software Configuration Guide to get the cellular link working, but I'm a bit confused.
In following the above document, I'm following the instructions in the Configuring Cisco 4G LTE NIM section, where it has you verify your signal strength and setup a data profile and all that, which I have done. However, even after configuring the default data profile 1 with our APN, username, and password, the data profile remains inactive and the cellular link will not come up (specifically interface cellular 0/1/0
ROUTER1(config-if)#do sh run int ce0/1/0 Building configuration... Current configuration : 80 bytes ! interface Cellular0/1/0 ip address negotiated no snmp trap link-status end ROUTER1(config-if)# ROUTER1(config-if)#end ROUTER1# ROUTER1# ROUTER1# ROUTER1# ROUTER1#show cell 0/1/0 profile Profile password Encryption level = 7 Profile 1 = INACTIVE* ** -------- PDP Type = IPv4 Access Point Name (APN) = notreal.fake.com Authentication = CHAP Username = helloworld_123-45 Password = 1234567890ABCD * - Default profile ** - LTE attach profile Configured default profile for active SIM 0 is profile 1. ROUTER1# ROUTER1# ROUTER1# ROUTER1# ROUTER1#show ip int br Interface IP-Address OK? Method Status Protocol GigabitEthernet0/0/0 unassigned YES NVRAM down down GigabitEthernet0/0/1 unassigned YES NVRAM down down GigabitEthernet0/0/2 unassigned YES NVRAM down down Cellular0/1/0 unassigned YES NVRAM down down Cellular0/1/1 unassigned YES NVRAM administratively down down GigabitEthernet0 unassigned YES NVRAM down down Loopback0 unassigned YES unset up up ROUTER1# ROUTER1# ROUTER1# ROUTER1# ROUTER1#show cell 0/1/0 firmware Idx Carrier FwVersion PriVersion Status 1 ATT 02.20.03.00 002.020_000 Active 2 BELL 02.20.03.00 000.010_000 Inactive 3 GENERIC 02.20.03.00 002.017_001 Inactive 4 ROGERS 02.20.03.00 000.011_000 Inactive 5 SPRINT 02.20.03.22 002.020_000 Inactive 6 TELUS 02.20.03.00 000.011_000 Inactive 7 VERIZON 02.20.03.22 002.026_001 Inactive Firmware Activation mode = MANUAL ROUTER1#
However, if I configure a Dialer Watch-List on the router and attach it to the cellular interface as a Watch-Group, the cell0/1/0 interface comes up just fine:
ROUTER1(config)#dialer watch-list 1 ip 5.6.7.8 0.0.0.0 ROUTER1(config)#dialer watch-list 1 delay route-check initial 60 ROUTER1(config)#dialer watch-list 1 delay connect 1 ROUTER1(config)# ROUTER1(config)# ROUTER1(config)#int cellular 0/1/0 ROUTER1(config-if)# ROUTER1(config-if)#dialer in-band ROUTER1(config-if)#dialer watch-group 1 ROUTER1(config-if)# ROUTER1(config-if)# ROUTER1(config-if)# *Feb 9 13:41:02.097: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to up *Feb 9 13:41:03.097: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to up ROUTER1(config-if)# ROUTER1(config-if)# ROUTER1(config-if)# ROUTER1(config-if)#end ROUTER1# ROUTER1# *Feb 9 13:41:13.566: %SYS-5-CONFIG_I: Configured from console by console ROUTER1# ROUTER1# ROUTER1# ROUTER1# ROUTER1# ROUTER1# ROUTER1#show cellular 0/1/0 profile Profile password Encryption level = 7 Profile 1 = ACTIVE* ** -------- PDP Type = IPv4 PDP address = W.X.Y.Z IPv4 PDP Connection is successful Access Point Name (APN) = notreal.fake.com Authentication = CHAP Username = helloworld_123-45 Password = 1234567890ABCD Primary DNS address = A.B.C.D Secondary DNS address = E.F.G.H * - Default profile ** - LTE attach profile Configured default profile for active SIM 0 is profile 1. ROUTER1# ROUTER1# ROUTER1#show run int cellular 0/1/0 Building configuration... Current configuration : 156 bytes ! interface Cellular0/1/0 ip address negotiated ip tcp adjust-mss 1390 dialer in-band dialer watch-group 1 no snmp trap link-status pulse-time 1 end ROUTER1# ROUTER1# ROUTER1#show ip int br Interface IP-Address OK? Method Status Protocol GigabitEthernet0/0/0 unassigned YES NVRAM down down GigabitEthernet0/0/1 unassigned YES NVRAM down down GigabitEthernet0/0/2 unassigned YES NVRAM down down Cellular0/1/0 W.X.Y.Z YES IPCP up up Cellular0/1/1 unassigned YES NVRAM administratively down down GigabitEthernet0 unassigned YES NVRAM down down Loopback0 unassigned YES unset up up ROUTER1# ROUTER1#
However, in the above linked document, in the Features Not Supported in Cisco 4G LTE NIM section, we see that External Dialers are not supported for this NIM card. But I couldn't get the cellular link to come up without some Dialer config.
So, I suppose my questions are:
1. Why did I need a Dialer Watch-List for the cellular link to come up, when External Dialers supposedly aren't supported for this NIM card? (i.e. what purpose does the Dialer config serve when dealing with cellular connections?)
2. Could I have gotten the cellular link to come up without any Dialer config?
Looking forward to learning more about this one. Thanks!
Solved! Go to Solution.
02-10-2022
02:10 PM
- last edited on
02-13-2022
09:31 PM
by
Translator
OK, so I've done some research and testing on this router over the past few days, and I'm posting my findings here as others may find it helpful information.
DISCLAIMER: This post is meant for informational purposes only. Use this config at your own risk. There are many other options for configuring cellular connections, so please review the Cisco documentation for any additional config you may need (like config for taking the cell interface down if it hasn't had traffic in X number of seconds, etc.). Also, if I have misspoken in anything below, please (kindly) reply with a correction. Thanks!
Sources:
A Quick Note on the distinction between "Controller" vs. "Interface" (taken from https://community.cisco.com/t5/switching/difference-between-interface-and-controller-interface/td-p/2931591 ) :
This is the basic logic: The controller represents the hardware of the interface module whose configuration affects all interfaces on the module. Configuring the controller is typical for ISDN or selected DSL interface modules. Ethernet interfaces or plain Serial interfaces do not have similar configurable properties, and so there is no controller configuration available for them.
Older IOS Cell Config
In more recent IOS versions:
So, the steps we need to take to get the cellular working on a modern router IOS would be:
Creating the Cell profile
Make sure the Cell Profile is attached to the Cellular Controller
If the attach profile details are not provided by or are not relevant to the carrier, you can assign the same number as the data profile. Otherwise, create a profile with the carrier-specific attach profile
Turn off Auto-SIM on the Cell Controller (at least in my situation)
Configure a dialer watch-list on the router (if doing "Always On" cell) or a dialer-list (if doing "Triggered" cell)
Configure the cell interface
CAUTION: Configure static route for cellular interface IF NEEDED
Modern config example for "Triggered" cellular
! Again this profile config is if you're doing authentication (in my case, CHAP)
cellular 0/1/0 lte profile create 1 [APN] chap [username] [password] ipv4
conf t
controller cellular 0/1/0
no lte firmware auto-sim
lte sim data-profile 1 attach-profile 1 slot 0
exit
dialer-list 1 protocol ip permit
dialer in-band
dialer-group 1
exit
! CAREFULLY add any default routes you need (as discussed above)
Modern config example for "Always On" cellular:
conf t
exit
dialer watch-list 1 5.6.7.8 0.0.0.0
dialer in-band
exit
! CAREFULLY add any default routes you need!
! COULD also do BGP if needed
Troubleshooting
02-09-2022 12:10 PM
UPDATE: after about 17 minutes the cell 0/1/0 interface went DOWN again (no changes to config were made) because it looks like the cell modem itself went down, and then it came back up again. Not sure why modem went up/down?
ROUTER1# Feb 9 14:06:17.578: %CELLWAN-2-MODEM_DOWN: Modem in slot 0/1 is DOWN ROUTER1# .Feb 9 14:07:06.892: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to down .Feb 9 14:07:07.892: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to down ROUTER1# .Feb 9 14:08:09.911: Setting the band preference on modem for sim 0 to match the configured settings ROUTER1# .Feb 9 14:08:22.914: %CELLWAN-2-MODEM_UP: Modem in slot 0/1 is now UP .Feb 9 14:08:23.116: %CELLWAN-2-MODEM_RADIO: Cellular0/1/0 Modem radio has been turned on ROUTER1# .Feb 9 14:08:30.127: %LINK-5-CHANGED: Interface Cellular0/1/0, changed state to administratively down ROUTER1# .Feb 9 14:08:30.330: %CELLWAN-2-MODEM_RADIO: Cellular0/1/0 Modem radio has been turned off .Feb 9 14:08:31.531: %CELLWAN-2-MODEM_RADIO: Cellular0/1/0 Modem radio has been turned on ROUTER1# .Feb 9 14:08:35.531: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to down ROUTER1# .Feb 9 14:08:44.277: %LINK-3-UPDOWN: Interface Cellular0/1/0, changed state to up .Feb 9 14:08:45.278: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/1/0, changed state to up ROUTER1#
02-09-2022
01:26 PM
- last edited on
02-13-2022
06:23 PM
by
Translator
it is difficult to see what you have configured. Post the output of
sh run
02-09-2022 01:57 PM
@Georg Pauwen sure no problem, see below:
ROUTER1#sh run Building configuration... Current configuration : 11618 bytes ! ! Last configuration change at 13:41:13 CST Wed Feb 9 2022 ! version 17.3 service nagle service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime service timestamps log datetime msec localtime service password-encryption service call-home platform qfp utilization monitor load 80 no platform punt-keepalive disable-kernel-core ! hostname ROUTER1 ! boot-start-marker boot-end-marker ! ! vrf definition Mgmt-intf ! address-family ipv4 exit-address-family ! address-family ipv6 exit-address-family ! logging buffered 65536 logging persistent size 1000000 enable secret 9 $blahblah ! aaa new-model ! ! aaa authentication login default group tacacs+ local line aaa authentication login NO-TACACS line aaa authorization exec default group tacacs+ if-authenticated aaa authorization commands 0 default group tacacs+ local none aaa authorization commands 1 default group tacacs+ local none aaa authorization commands 15 default group tacacs+ local none aaa accounting exec default start-stop group tacacs+ aaa accounting commands 1 default start-stop group tacacs+ aaa accounting commands 5 default start-stop group tacacs+ aaa accounting commands 15 default start-stop group tacacs+ ! ! ! ! ! ! aaa session-id common clock timezone CST -6 0 clock summer-time CDT recurring ! ! ! ! ! ! ! ip name-server A.B.C.D E.F.G.H ip domain list a.com ip domain list b.com ip domain timeout 1 ip domain lookup source-interface Loopback0 ip domain name c.com ! ! ! login on-success log ! ! ! ! ! ! ! subscriber templating ! ! ! ! ! multilink bundle-name authenticated no device-tracking logging theft device-tracking policy DT_trunk_policy trusted-port device-role switch no protocol udp ! ! ! ! password encryption aes ! ! crypto pki trustpoint TP-self-signed-blah enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-blah revocation-check none rsakeypair TP-self-signed-blah ! crypto pki trustpoint SLA-TrustPoint enrollment pkcs12 revocation-check crl ! ! crypto pki certificate chain TP-self-signed-BLAH certificate self-signed 01 ! cert stuff removed quit crypto pki certificate chain SLA-TrustPoint certificate ca 01 ! cert stuff removed quit ! ! license udi pid ISR4331/K9 sn SERIALNUMBER license boot level appxk9 memory free low-watermark processor 69075 ! diagnostic bootup level minimal ! spanning-tree extend system-id ! username tombstone privilege 15 secret 9 $supersecret ! redundancy mode none ! ! controller Cellular 0/1/0 no lte firmware auto-sim ! ! ! lldp run ! ! ! ! ! ! ! ! interface Loopback0 no ip address ! interface GigabitEthernet0/0/0 no ip address negotiation auto ! interface GigabitEthernet0/0/1 no ip address media-type rj45 negotiation auto ! interface GigabitEthernet0/0/2 no ip address media-type sfp negotiation auto ! interface Cellular0/1/0 ip address negotiated ip tcp adjust-mss 1390 dialer in-band dialer watch-group 1 no snmp trap link-status pulse-time 1 ! interface Cellular0/1/1 no ip address shutdown ! interface GigabitEthernet0 vrf forwarding Mgmt-intf no ip address negotiation auto ! ip tcp path-mtu-discovery no ip http server no ip http secure-server ip forward-protocol nd no ip forward-protocol udp tftp no ip forward-protocol udp domain no ip forward-protocol udp time no ip forward-protocol udp netbios-ns no ip forward-protocol udp netbios-dgm no ip forward-protocol udp tacacs ip ftp source-interface Loopback0 ip tftp source-interface Loopback0 ip route 0.0.0.0 0.0.0.0 Cellular0/1/0 ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 192.168.0.1 ip tacacs source-interface Loopback0 ip ssh source-interface Loopback0 ip ssh version 2 ip ssh dscp 16 ! ! ! logging trap notifications logging origin-id hostname logging source-interface Loopback0 logging host A.B.C.D dialer watch-list 1 ip 5.6.7.8 0.0.0.0 dialer watch-list 1 delay route-check initial 60 dialer watch-list 1 delay connect 1 ! snmp ifmib ifindex persist ! tacacs-server directed-request tacacs server SERVER1 address ipv4 A.B.C.D key 6 supersecrettacacskeydontlookplz ! ! ! ! ! control-plane ! ! line con 0 exec-timeout 30 0 password 7 supersecret7password logging synchronous login authentication NO-TACACS stopbits 1 line aux 0 session-timeout 30 exec-timeout 30 0 password 7 supersecret7password logging synchronous login authentication NO-TACACS stopbits 1 line vty 0 4 session-timeout 30 exec-timeout 30 0 password 7 supersecret7password logging synchronous transport input ssh line vty 5 15 session-timeout 30 exec-timeout 30 0 password 7 supersecret7password logging synchronous transport input ssh ! call-home ! If contact email address in call-home is configured as sch-smart-licensing@cisco.com ! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications. contact-email-addr sch-smart-licensing@cisco.com profile "BLAH" active destination transport-method http ntp source Loopback0 ntp server A.B.C.D ! ! ! ! ! ! end ROUTER1#
02-10-2022
02:10 PM
- last edited on
02-13-2022
09:31 PM
by
Translator
Sources:
conf t
exit
dialer in-band
dialer-group 1
exit
conf t
exit
dialer in-band
exit
Troubleshooting
