SSH'ing to VRF-enabled ASR1000 router on DIA (external) interfaces
ryan.meskill
Hello-I have multiple routers which run multiple VRFs of which I thought were configured for external access from our public VPN NAT but, on losing access to a site that was still technically online, we noticed we could not connect externally. It seems, indeed, I am only able to connect to the router via the Mgmt-intf VRF, but my ACLs are permitting access from all RFC1918 addresses and a specific external IP (SSH and ICMP) but while ICMP works, SSH does not. Am I missing a configuration somewhere to permit SSH for back-door access via my provider-issued IP?
Extended IP access list ADMIN_ACCESS
    10 permit tcp 10.0.0.0 0.255.255.255 any eq 22
    20 permit tcp 172.16.0.0 0.15.255.255 any eq 22 (72 matches)
    30 permit tcp 192.168.0.0 0.0.255.255 any eq 22
    40 permit tcp x.x.x.x 255.255.255.255 any eq 22
line vty 0 4
 access-class ADMIN_ACCESS in vrf-also
 exec-timeout 15 0
 logging synchronous
 transport preferred none
 transport input ssh
 transport output ssh
line vty 5 15
 exec-timeout 15 0
 logging synchronous
 transport input ssh
ip access-list extended INET_INBOUND
permit icmp x.x.x.x 255.255.255.255 any
permit ip x.x.x.x 255.255.255.255 any
interface GigabitEthernet0/1/4
 vrf forwarding INET
 ip address x.x.x.x 255.255.255.248
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip access-group INET_INBOUND in
I'm able to ping the public IP of that interface and have tunnels terminating on it (also covered in INET_INBOUND) but ssh doesn't work, leading me to believe there may be some sort of missing ssh permission on the router that I'm not aware of...
balaji.bandi
ADMIN_ACCESS
you have all RFC1918 address in that group, but when the ssh coming in from public, the IP address is public IP right ?
remove the access class and test it. is that works ? (Hope from internal network it works ssh right ?
line vty 0 4
BB
Hello
What was perfromed for you to lose access you already had?
You dont so any nat applied interfaces?
Kind Regards
Paul
