ISR 4351 + Ethernet Switch Module
Tony T.
Hello-
I have a ISR 4351, IOS XE version 3.16.4b.s, with a 24 port ethernet switch module inserted. I tried logging into the switch module with the "service-module gi-1/0 session" command  but that didn't work. So looked through the commands (?) at the exec mode and found "hw-module session gi-1/0" command. That worked and allowed me to access the switch module.
However, once in the switch module I could NOT use Ctrl+Shift+6+x. I tried pressing those characters at the same time, and even pressing Ctrl+Shift+6, then x, but nothing worked. I then tried rebooting the switch module in hopes of the device putting back at the router exec mode CLI but that didn't work either. I actually had to hard boot the router itself to get back to the router exec mode CLI.
I did all of this in my lab environment, so it's not a big deal. But I can't reboot the whole router in production. Can someone help me with this? I searched all over for something online but couldn't find anything that specifically mentions switch module for IOS XE (ISR 4351).
Thanks in advance for your assistance.
Tony
balaji.bandi
i may be missed here - not sure what terminal client you using, putty or secure CRT ? or any other ?
baudrate is : 9600
parity is : none
databits are : 8
flowcontrol : none
May be you can try :
Ctrl-a and Ctrl-q
BB
balaji.bandi
baudrate is : 9600
parity is : none
databits are : 8
flowcontrol : none
Ctrl-a and Ctrl-q
BB
That worked, thank you so much. If you don't mind me asking, where did you discover that?
Tony
we use normally at the workplace and it should be documented in cisco documentation also.
BB
I think when you access the module, it tells you how to exit. It should look something like below:
Router# hw-module session 1/0
Establishing session connect to subslot 1/0
To exit, type ^a^q
