ISR 4400 - 0 Bytes Free in Flash Memory
Daniel Smith
Just cracked open what I believe to be a new ISR 4400, and wanted to update code to our latest approved version. This was not successful with error message about Not Enough Space on Device. When checking bootflash; I find the following:
7194652672 bytes total (0 bytes free)
Surprised to see this as I have upgraded many 4400s with no challenges. I did find reference on line to 'request software package clean' with no change in the situation...any suggestions?
5 Replies 5
balaji.bandi
what is current version of code running - show version, and post dir flash:
If you are running install mode, try cleanup "request platform software package clean" - check the version of code running and run the command - since you run that one if no change,
we need to look what is occupied  boot flash:  dir flash: or dir bootflash:
BB
What is ‘Install Mode’ ?
Leo Laohoo
Post the complete output to the command "dir".
Daniel Smith
Thanks for the responses. A coworker reached out to me and advised to remove some directories from flash to free up space. Found that bootflash:/core had tons of large files.
yes that what i was guessing that folder have many logs, glad you able to freeup the space and able to upgade your router as you intend to do.
BB
