03-11-2021 12:45 AM
Hi ,
ISR 4451 Router is booting rommon mode in loop, and no IOS image found in flash.
initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.2(1r), RELEASE SOFTWARE
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
ISR4451-X/K9 platform with 8388608 Kbytes of main memory.
Please help me to resolve this issue
Altamus
03-11-2021 01:37 AM
If the router does not have a valid IOS-XE file then you'll need to transfer the IOS-XE file into the box.
The fastest way is to use USB thumb drive and force the router to boot the IOS using the following command:
boot usbflash0:filename.bin
03-11-2021 01:39 AM
Power off the Device - Power on the device and post complete logs to understand the issue.
or follow one of the proceedure to load IOS
get the IOS downloaded from cicso site. - format USB with fat32, copy the image to USB:
Pwoer down the device, Power on the device use break sequence CTRL+break
you get prompt ROMMON >
follow below guide to boot from USB:
Once booted success copy the image from USB to flash ( before copy check any image available in flash:
chang the boot variable to boot from flash.
any issue post the logs here.
