ISR 4451x Airflow
bret
Level 3
Level 3
Does anyone know if there is an airflow option for the 4451x? Currently, the airflow is back to front, which screws up my hot/cold isle rack layout. I pulled the fan module and it looks like the fans can probably be reversed, but without taking a screwdriver to it I am not 100% sure it will work. Any help will be appreciated.
Bret
EGB
We are in the same situation, did you succesfully reverse airflow  from fan tray and PSU's ?
babarshah1
facing the same issue.. is there any one to confirm plz. can we reverse the direction of air flow on isr 4451 router?
