ISR 4451xk9 licensing question
Amafsha1
Level 2
Level 2
Hello, I'm trying to figure out if I can enable BFD with the current license I have in my isr 4451xk9 router:
From what I understand BFD requires the appxk9 license.  Does the below mean that I have it(paid for), but just need to activate in iOS?
Router1#sh license feature
Feature name Enforcement Evaluation Subscription Enabled RightToUse
appxk9 yes yes no no yes
uck9 yes yes no no yes
securityk9 yes yes no no yes
ipbasek9 no no no yes no
FoundationSuiteK9 yes yes no no yes
AdvUCSuiteK9 yes yes no no yes
cme-srst yes yes no no yes
hseck9 yes no no no no
throughput yes yes no no yes
internal_service yes no no no no
Sorry about the formatting, let me know if you would like me to get a screen cap instead.
You dont have the appxk9 license. You can enable it as RTU
More info between RTU and Permanenet license in below thread
https://community.cisco.com/t5/routing/diffrence-between-right-to-use-and-permanent-license/td-p/2659344
7 Replies 7
nazimkha
As you have listed, BFD requires the appxk9 license.
It looks like the appxk9 is not installed in your ISR.
Can confirm if you post the output of 'show license' and 'show ver',
Nazim
Please do not forget to rate the post !
#show license
Index 1 Feature: appxk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
Index 2 Feature: uck9
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
License Count: 0/0 (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
Index 10 Feature: internal_service
#show ver
Cisco IOS XE Software, Version 16.03.06
Cisco IOS Software [Denali], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.3.6, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 28-Feb-18 16:17 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
WA-SEA-DC-WAN32 uptime is 19 weeks, 6 days, 18 hours, 56 minutes
Uptime for this control processor is 19 weeks, 6 days, 18 hours, 57 minutes
System returned to ROM by PowerOn
System restarted at 16:59:52 PDT Wed Apr 4 2018
System image file is "bootflash:isr4400-universalk9.16.03.06.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4451-X/K9 (2RU) processor with 1650898K/6147K bytes of memory.
Processor board ID FGL210310UR
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7341807K bytes of flash memory at bootflash:.
0K bytes of at webui:.
Thank you sir.  i was looking for a link like that.  So during the thread, I feel they didn't fully answer if the RTU will "expire" or not...   So If I enable it as RTU and configure BFD, will it just stop working one day?
RTU licenses are honor based licenses at do not expire.
got it.  Do you know how to turn it on in iOS so I can config BFD?
They will stop working when the EVALUATION period passes and after next reboot it will be deactivated
