ISR 4K IOS-XE: ip dhcp class xxx : missing option xx
jean1
Why this command isn't avalaible on ISR 4K - IOS-XE vs IOS ?
     option 60 hex xxxxxxx
I'am using this configuration on IOS :
ip dhcp pool DHCP-TEST-ALL
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 class TEST1
  address range 192.168.1.100 192.168.1.149
 class TEST2
  address range 192.168.1.150 192.168.1.200
 ip dhcp class TEST1
   option 60 hex a4a3a2a1f
  ip dhcp class TEST2
and i need to migrate this on ISR 4K. I'can't use the same command with ISR4K on IOS-XE ?
Best regards
There is no other method to match option 60 send by my device in the dhcp server ?
you can use "option 60 hex" in pool but not in class
Yes, i can use options in the pool, but it's only to send options to my clients ? not to check if this option is send by my client in BOOTP request ?
