ISR 4K series Routers
vimal vikraman
Need help to understand how many L3 ports are by default there on a ISR4321/K9 router. is it 2 GE ports with additional port with an SFP Module or is it 2 ports where 1 is RJ-45 and another one is with SFP module?
Iulian Vaideanu
Level 4
Level 4
Two L3 ports - one is RJ-45 and for the other one you can choose between RJ-45 and SFP.
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/Overview.html
  • Two GE ports allocated among two RJ45 and one SFP as:
One combo port with 10/100/1000 RJ-45 Ethernet port or SFP Ethernet port (labeled GE0/0/0)
One dedicated 10/100/1000 RJ-45 Ethernet port (labeled GE0/0/1)
Thanks Lulian
