Voice Gateway Connectivity issue
shazeb051
Dear All,
VG connectivity problem:
I have two core switch nexus 700 and one voice gateways.. VG also having two giga ports i connected one two one core with management ip. Now i have to connect to core2.. But for other port in VG i am unable to give same range of ip as management.
The 1&2 are redundant to each other. in VG Its says ip over loops with management vlan ip. if i give any other range its not taking management vlan ip.
Suppose Vg ip is 11.11.14.3 and management is 11.11.14.0 and core 1 is 11.11.14.11How can i connect to 2nd core with same Vg???
saif musa
Level 4
Level 4
Whats the model of your VG, (vg224, vg248 .. etc ). Also, what you finally trying to achieve from connecting both Ethernet ports of your device ??
Dear Saif
VG mode is Cisco ISR 3945.
from Ethernet it will access management vlan and it send all call manager calls through that port.
regards,
Hi;
On the VG you can configure Port-channel, which will double your bandwidth & redundancy. And on Nexus 7000 you can create L2 vPC. On Nexus 7000 create access port (vPC port-channel) and run HSRP.
VG:
interface Port-channel10
 ip address 11.11.14.3 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no shut
interface GigabitEthernet0/0
 no ip address
channel-group 10
interface GigabitEthernet0/1
 no ip address
 channel-group 10
Nexus 7000-1:
 switchport
 switchport mode access
 switchport access vlan X
 vpc 10
no shut
interface E1/1
 switchport
 channel-group 10
interface vlan X
 ip add 11.11.14.12 255.255.255.0
 hsrp 11
  ip 11.11.14.11
  priority 150
  preempt
  no shut
Nexus 7000-2:
 switchport
 vpc 10
no shut
interface E1/1
 switchport
 channel-group 10
interface vlan X
 ip add 11.11.14.13 255.255.255.0
 hsrp 11
  ip 11.11.14.11
  no shut
Thanks & Best regards;
Hi shoaib,
i have created port channel 1 already in both core i will try above solution and get you back soon
thanks and regards.
