ISR 851 resetting
richardhanel
I just pulled an 851 ISR from my client as it was wasn't being used.  Another consultant put in a DLink 601 Router instead.  I would like to put the 851 back in operation for my new client but I can't reset the router.  I tried to do a Break but it didn't work.  I also tried the reset button on the unit it too didn't work.  When connected via the console port this is what comes up when rebooted:
System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Copyright (c) 2006 by cisco Systems, Inc.
C850 series (Board ID: 4-149) platform with 65536 Kbytes of main memory
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
Booting flash:/c850-advsecurityk9-mz.124-4.T8.bin
Self decompressing the image : #################################################
################### [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(4)T8, REL
EASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sat 11-Aug-07 03:29 by khuie
Image text-base: 0x8002008C, data-base: 0x811EED90
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 851 (MPC8272) processor (revision 0x200) with 59392K/6144K bytes of memory
Processor board ID FHK120823P3
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
128K bytes of non-volatile configuration memory.
20480K bytes of processor board System flash (Intel Strataflash)
no autostate
% Invalid input detected at '^' marker.
sntp source FastEthernet4
Translating "stipp2.srv.hcvlny.cv.net"...domain server (255.255.255.255)
hostname = stipp2.srv.hcvlny.cv.net unreachable....
I am aware that the "Password Recovery Functionality is Disabled".  I would like to know is there a way to bypass this.  I don't care if I loose the current configuration as it wasn't being used.  I just want to put this into operation.  I really don't want to tell them that this is a paper weight.
In looking at another post from Dec. 2010, it said there was nothing that can be done.  I'm just hoping that there was something found by now.
Any help would be very helpful.
Rich.
Leo Laohoo
This works.  I've tried it myself.
http://www.heinzulm.com/password.php
Please don't forget to rate our useful posts.  Thanks.
