ISR G2 router support 150 Mbps ISP link
Shakeeb AlDari
i have a dedicated Internet link of 150 Mbps from ISP, what is the recommended CE router to be implemented to support this speed? can i use 1900 series.
Leo Laohoo
3945E would be your choice.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Cisco's whitepaper's (attached) figure 1 (last page) recommends a 3945 for 150 Mbps WAN link.  However, Cisco's recommendations are conservative, i.e. they try to insure you'll never have a performance issue using their recommendation.  If you don't expect to routinely saturate the link, you can often do fine going a "size" down or sometimes even two "sizes" down.  I.e. you might be okay with a 3925 or even a 2951.
Conversely if you think you may, in a year or two, need to increase your bandwidth, you might want to upsize.
