ISR4321/K9 DNS Configuration
callen15
Hello, After successfully getting our 161 VLAN (192.168.10.1/24) to NAT to VLAN 20 (10.4.20.253), I'm having issues with DNS resolution. I've been able to ping external IP addresses such as those in our production network and externally ex..(8.8.8.8).
I performed a packet capture on the switch that's connecting the 10.4.20.253 interface and was able to determine that DNS Queries are being sent out and returned to the 10.4.20.253 interface but for whatever reason, the 192 hosts aren't getting the reply.
Attached below is my ISR4321/K9 startup-config. Any help is greatly appreciated.
Building configuration...
Current configuration : 2987 bytes
! Last configuration change at
version 16.6
service password-encryption
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret
enable password
no aaa new-model
ip name-server 10.4.100.25 10.7.100.24
no ip domain lookup
ip domain name organization.local
subscriber templating
license udi pid ISR4321/K9
diagnostic bootup level minimal
archive
log config
hidekeys
username admin privilege 15 secret 5
redundancy
mode none
vlan internal allocation policy ascending
interface Null0
no ip unreachables
interface GigabitEthernet0/0/0
description WAN to organization
no ip address
negotiation auto
interface GigabitEthernet0/0/0.2
encapsulation dot1Q 2 native
ip address 10.4.1.49 255.255.255.0
interface GigabitEthernet0/0/0.20
encapsulation dot1Q 20
ip address 10.4.20.253 255.255.255.0
ip nat outside
ip virtual-reassembly
interface GigabitEthernet0/0/0.100
encapsulation dot1Q 100
ip address 10.4.100.5 255.255.255.0
interface GigabitEthernet0/0/1
description LAN to INF
no ip address
negotiation auto
interface GigabitEthernet0/0/1.2
interface GigabitEthernet0/0/1.161
encapsulation dot1Q 161
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip nat pool NAT_POOL 10.4.20.253 10.4.20.253 netmask 255.255.255.0
ip nat inside source list 1 pool NAT_POOL overload
ip forward-protocol nd
ip ftp username admin
ip ftp password 7
no ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.4.20.1
ip ssh version 2
ip access-list extended ALLOW_DNS
permit tcp any any
permit udp any any
ip access-list extended CAP-FILTER
permit ip any any
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.4.1.0 0.0.0.255
access-list 1 permit 10.4.20.0 0.0.0.255
control-plane
line con 0
logging synchronous
login local
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7
login local
transport input ssh
line vty 5 97
login local
transport input ssh
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
0 Replies 0
