BGP - Multihop and Multipath -
yhaas1
hope you can help me. I want to do bgp with two C1111 Routers with two links between the routers.
First direct connected and secound via multihop.
But I am not able to bring be secound link up.
Setup like this:
All Networks are /28.
This is my BGP config:
router bgp 100
bgp log-neighbor-changes
neighbor 10.31.4.18 remote-as 200
neighbor 10.31.4.18 fall-over bfd
neighbor 10.31.4.65 remote-as 200
neighbor 10.31.4.65 ebgp-multihop 4
neighbor 10.31.4.65 fall-over bfd
address-family ipv4
network 10.31.4.0 mask 255.255.255.240
network 10.31.4.16 mask 255.255.255.240
neighbor 10.31.4.18 activate
neighbor 10.31.4.65 activate
maximum-paths eibgp 5
exit-address-family
router bgp 200
neighbor 10.31.4.17 remote-as 100
neighbor 10.31.4.17 fall-over bfd
neighbor 10.31.4.49 remote-as 100
neighbor 10.31.4.49 ebgp-multihop 4
neighbor 10.31.4.49 fall-over bfd
address-family ipv4
network 10.31.4.32 mask 255.255.255.240
neighbor 10.31.4.17 activate
neighbor 10.31.4.17 soft-reconfiguration inbound
neighbor 10.31.4.49 activate
neighbor 10.31.4.49 soft-reconfiguration inbound
exit-address-family
Maybe there is only a simple trick I don't see...
Thanks!
27 Replies 27
balaji.bandi
config looks ok -  do they have reachability between IP ?
try source interface :
neighbor x.x.x.x update-source interface  x/x
BB
Thanks for your quick answer.
But it didn't bring it "up".
Here is the bgp output:
BGP neighbor is 10.31.4.65, remote AS 200, external link
Fall over configured for session
BFD is configured.
BGP version 4, remote router ID 0.0.0.0
BGP state = Active, down for never
Neighbor sessions:
0 active, is not multisession capable (disabled)
Stateful switchover support enabled: NO for session 0
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 0 0
Notifications: 0 0
Updates: 0 0
Keepalives: 0 0
Route Refresh: 0 0
Total: 0 0
Do log neighbor state changes (via global configuration)
Default minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
BGP table version 18, neighbor version 1/18
Output queue size : 0
Index 0, Advertise bit 0
Slow-peer detection is disabled
Slow-peer split-update-group dynamic is disabled
Sent Rcvd
Prefix activity: ---- ----
Prefixes Current: 0 0
Prefixes Total: 0 0
Implicit Withdraw: 0 0
Explicit Withdraw: 0 0
Used as bestpath: n/a 0
Used as multipath: n/a 0
Used as secondary: n/a 0
Outbound Inbound
Local Policy Denied Prefixes: -------- -------
Total: 0 0
Number of NLRIs in the update sent: max 0, min 0
Last detected as dynamic slow peer: never
Dynamic slow peer recovered: never
Refresh Epoch: 1
Last Sent Refresh Start-of-rib: never
Last Sent Refresh End-of-rib: never
Last Received Refresh Start-of-rib: never
Last Received Refresh End-of-rib: never
Sent Rcvd
Refresh activity: ---- ----
Refresh Start-of-RIB 0 0
Refresh End-of-RIB 0 0
Address tracking is enabled, the RIB does have a route to 10.31.4.65
Route to peer address reachability Up: 1; Down: 0
Last notification 2d05h
Connections established 0; dropped 0
Last reset never
External BGP neighbor may be up to 4 hops away.
External BGP neighbor NOT configured for connected checks (multi-hop no-disable-connected-check)
Interface associated: (none) (peering address NOT in same link)
Transport(tcp) path-mtu-discovery is enabled
Graceful-Restart is disabled
SSO is disabled
No active TCP connection
Last reset never
Can you able to ping 10.31.4.49 source 10.31.4.65 ?
BB
Right router:
ping 10.31.4.65
Sending 5, 100-byte ICMP Echos to 10.31.4.65, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
traceroute 10.31.4.65
Tracing the route to 10.31.4.65
VRF info: (vrf in name/id, vrf out name/id)
1 10.31.4.50 0 msec 4 msec 0 msec
2 10.31.4.82 0 msec 0 msec 4 msec
3 10.31.4.65 0 msec 4 msec *
Left router:
ping 10.31.4.49
Sending 5, 100-byte ICMP Echos to 10.31.4.49, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
traceroute 10.31.4.49
Tracing the route to 10.31.4.49
1 10.31.4.66 0 msec 0 msec 0 msec
2 10.31.4.81 0 msec 0 msec 4 msec
3 10.31.4.49 0 msec 0 msec *
I do not see any issue, until we missing any config, post full config both the routers:
just tested simple lab with your IP config, works straight away below example :
BB
Here it is, hope you see my mistake:
sh run
Building configuration...
Current configuration : 7264 bytes
! Last configuration change at 21:28:50 UTC Fri Jan 21 2022
version 16.10
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname XXXXXX
boot-start-marker
boot-end-marker
enable secret 9 XXXX
enable password XXXX
no aaa new-model
call-home
 ! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
 ! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
 contact-email-addr sch-smart-licensing@cisco.com
 profile "CiscoTAC-1"
  active
  destination transport-method http
  no destination transport-method email
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-1932404587
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1932404587
 revocation-check none
 rsakeypair TP-self-signed-1932404587
crypto pki trustpoint SLA-TrustPoint
 enrollment pkcs12
 revocation-check crl
crypto pki certificate chain TP-self-signed-1932404587
 certificate self-signed 01
        quit
crypto pki certificate chain SLA-TrustPoint
 certificate ca 01
        quit
license udi pid C1111-8P sn XXXXX
diagnostic bootup level minimal
username admin privilege 15 password 0 default
redundancy
 mode none
bfd map ipv4  10.31.4.64/28  10.31.4.49/32 mh-template1
bfd-template multi-hop mh-template1
 interval min-tx 120 min-rx 100 multiplier 3
vlan internal allocation policy ascending
interface Loopback0
 no ip address
interface Loopback1
 ip address 10.0.0.1 255.255.255.0
interface GigabitEthernet0/0/0
 ip address 10.31.4.17 255.255.255.240
 negotiation auto
 bfd interval 50 min_rx 50 multiplier 5
interface GigabitEthernet0/0/1
 ip address 10.31.4.49 255.255.255.240
 negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
 ip address 10.31.4.2 255.255.255.240
router eigrp 100
 bfd all-interfaces
router bgp 100
 neighbor 10.31.4.65 update-source GigabitEthernet0/0/1
 address-family ipv4
 exit-address-family
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route static bfd 10.31.4.65 10.31.4.49 unassociate
ip route 0.0.0.0 0.0.0.0 10.31.4.1
ip route 10.31.4.64 255.255.255.240 10.31.4.50
ip route 10.31.4.80 255.255.255.240 10.31.4.50
control-plane
line con 0
 transport input none
 stopbits 1
line vty 0 4
 password YYYYY
 login
end
sh run
Current configuration : 7384 bytes
! Last configuration change at 21:05:26 UTC Fri Jan 21 2022 by admin
version 16.10
service password-encryption
service call-home
hostname YYYYYY
boot-start-marker
boot-end-marker
enable secret 9 YYYYYY
no aaa new-model
call-home
  active
ip domain name cisco.com
crypto pki trustpoint TP-self-signed-1605323481
 subject-name cn=IOS-Self-Signed-Certificate-1605323481
 rsakeypair TP-self-signed-1605323481
 enrollment pkcs12
crypto pki certificate chain TP-self-signed-1605323481
        quit
 certificate ca 01
          quit
license udi pid C1111-8P sn YYYYYY
username admin password 7 YYYYYYY
redundancy
 mode none
bfd map ipv4  10.31.4.48/28  10.31.4.65/32 mh-template1
interface Loopback2
 ip address 10.0.1.1 255.255.255.0
 ip address 10.31.4.18 255.255.255.240
 negotiation auto
 ip address 10.31.4.65 255.255.255.240
 negotiation auto
interface Vlan1
 ip address 10.31.4.34 255.255.255.240
router eigrp 200
 bfd all-interfaces
router bgp 200
 neighbor 10.31.4.49 update-source GigabitEthernet0/0/1
 address-family ipv4
 exit-address-family
ip http server
ip route static bfd 10.31.4.49 10.31.4.65 unassociate
ip route 0.0.0.0 0.0.0.0 10.31.4.33
ip route 10.31.4.0 255.255.255.240 10.31.4.17
ip route 10.31.4.48 255.255.255.240 10.31.4.66
ip route 10.31.4.80 255.255.255.240 10.31.4.66
control-plane
line con 0
 stopbits 1
line vty 0 4
 login local
 transport input ssh
end
@yhaas1 ,
One more thing, this configure will not work for BFD. It needs to be changed as follow:
bfd map ipv4  10.31.4.65/32  10.31.4.49/32 mh-template1
In place of
and
bfd map ipv4  10.31.4.49/32  10.31.4.65/32 mh-template1
in place of
For more information, please refer to this IOS-XE configuration document.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/configuration/xe-16/irg-xe-16-book/bfd-bgp-multihop-client-support-and-cbit-ipv-and-ipv.html
Harold Ritter
Hi @yhaas1 ,
I doubt BFD multihop is supported on the C1111. Can you try removing BFD from the session and see if it fixes the issue.
router bgp 100
no neighbor 10.31.4.65 fall-over bfd
router bgp 200
no neighbor 10.31.4.49 fall-over bfd
Thanks for the answer.
I removed BFD like you wrote but BGP Session is not coming up.
KR
Hi @yhaas1 ,
It looks like BGP BFD multihop is indeed supported after all. As @MHM Cisco World  mentioned, you will need to configure the following for the BGP BFD multihop to work:
router bgp 100
neighbor 10.31.4.65 fall-over bfd multi-hop
router bgp 200
neighbor 10.31.4.49 fall-over bfd multi-hop
Hi @yhaas1 ,
It is a good idea to make sure your configuration works without the "fall-over bfd" first. Once you get it to work without BFD, you can go ahead and apply the "fall-over bfd".
To troubleshoot why the BGP session does not come up even without BFD, start by addressing the following status from the BGP output you provided:
Last reset never
I removed all BFD config.
But the output is like this:
BGP state = Idle, down for never
Neighbor sessions:
BGP table version 21, neighbor version 1/21
Sent Rcvd
Prefixes Total: 0 0
Outbound Inbound
Total: 0 0
Refresh Epoch: 1
Sent Rcvd
Last notification 3d01h
Last reset never
SSO is disabled
Hi @yhaas1 ,
Did you just remove the BFD config under BGP?
Can you please provide the "sh runn | sec bfd" output.
Also what IOS-XE version are you running on the C1111?
BTW, I did a quick recreate and I have this same setup working with BFD in my virtual lab using a CSR1000v in place of the C1111. Here is the relevant configuration.
hostname Router-Right
interface Loopback1
 no bfd interval 50 min_rx 50 multiplier 5
router bgp 100
 address-family ipv4
 exit-address-family
hostname Router-Left
interface Loopback2
router bgp 200
 address-family ipv4
 exit-address-family
I tried your config on the C111 and it is not working.
Version is: Cisco IOS XE Software, Version 16.10.01b
 BFD is configured.
  Neighbor sessions:
  BGP table version 29, neighbor version 1/29
                                 Sent       Rcvd
    Prefixes Total:                 0          0
                                   Outbound    Inbound
    Total:                                0          0
  Refresh Epoch: 1
                                       Sent       Rcvd
  Route to peer address reachability Up: 4; Down: 0
    Last notification 05:33:40
  Last reset never
  SSO is disabled
