ISR4321 VDSL couldn't detect when configure mode auto
Looi Siew Key
We have 1 router ISR 4321 which add ATM module into it.
Deploy with "controller vdsl 0/2/0" as virtual DSL interface referring to dialer 1 (to ISP).
When configure "operating mode auto" inside "controller vdsl 0/2/0" interface, it doesn't able to detect which ISP protocol is using.
Whenever configured using manual way can work, example like "operating mode adsl2+"
Only 1 of the branch causing this issue and temporary running using manual protocol configured. Other branch using auto mode works fine.
Configuration syntax in ISR 4321;
     operating mode auto (this command will not appear after configured)
Firmware:
IOS XE v03.16.05.S - extended support release
keglass
Level 7
Level 7
Looi Siew Key,
I recommend you also post this to the Cisco Support Community for more information and access to technical support.
https://supportforums.cisco.com/
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
keglass
Level 7
Level 7
Looi Siew Key,
I hope this helps.
Kelli Glass
Hi Kelly,
Thanks for your update.
