ISR4351 Router license question
JaganV
Hi guys,
I need some clarification on this:
My router shows license info as below output (ISR4351k9). This router is used for normal routing out internet traffic.
Shouldn't the basic ipbasek9 be stated as "permanent" instead of "None"?
The "SL-4350-IPB-K9" was part of the item that we ordered.
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 securityk9 EvalRightToUse securityk9
ipbase ipbasek9 None ipbasek9
Router#sh license feature
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
appxk9                   yes          yes         no             no       yes
uck9                     yes          yes         no             no       yes
securityk9               yes          yes         no             no       yes
ipbasek9                 no           no          no             no       no
FoundationSuiteK9        yes          yes         no             no       yes
AdvUCSuiteK9             yes          yes         no             no       yes
cme-srst                 yes          yes         no             no       yes
hseck9                   yes          no          no             no       no
throughput               yes          yes         no             no       yes
internal_service         yes          no          no             no       no
Index 3 Feature: securityk9
Period left: 8 weeks 3 days
Period Used: 17 hours 36 minutes
License Type: EvalRightToUse
License State: Active, In Use
License Count: Non-Counted
License Priority: Low
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Period left: Not Activated
Period Used: 0 minute 0 second
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 6 Feature: AdvUCSuiteK9
What we ordered:
ISR4351/K9-Cisco ISR 4351 (3GE,3NIM,2SM,4G FLASH,4G DRAM,IPB)
CON-SSSNT-ISR4351K-SOLN SUPP 8X5XNBD Cisco ISR 4351 (3GE3NIM2SM4G FLASH4G D
SL-4350-IPB-K9-IP Base License for Cisco ISR 4350 Series
PWR-4450-AC-AC Power Supply for Cisco ISR 4450 and ISR4350
CAB-3P-JPN-AC Power Cord, C13, 3 Prong Plug, 2.3M
MEM-FLSH-4G-4G Flash Memory for Cisco ISR 4300 (Soldered on motherboard)
POE-COVER-4450-Cover for empty POE slot on Cisco ISR 4450
MEM-43-4G-4G DRAM (1 x 4G) for Cisco ISR 4300
NIM-BLANK-Blank faceplate for NIM slot on Cisco ISR 4400
SM-S-BLANK-Removable faceplate for SM slot on Cisco 2900,3900,4400 ISR
SISR4300UK9-1612-Cisco ISR 4300 Series IOS XE Universal
Leo Laohoo
The most "basic" level for a router is "ipbase".
As Leo stated- your base level is ipbase which is what your router should be running at boot. You can type show version to verify.
