ISR4431 - HSECK9
Andrey.A
Hi all,
Is it possible to activate hseck9 license for evaluation period of time, without buying and installing it?
I can see that from conf t, there is a command:
ISR_4431(config)#license feature ?
hseck9 Enable hseck9 license
ISR_4431(config)#exit
 But I'm not sure what does this command do and do you need to reload router or anything? Anyone had some experience with this?
Andrey
6 Replies 6
what are your options after:
ISR_4431(config)#license ?
Check if there is a command 'license right-to-use'...
Hi Georg,
Please see below:
accept Accept all further License Agreements
agent Configure LIC_AGENT
boot license boot config commands
call-home license call-home config commands
feature License features
smart Smart licensing
udi license udi
ISR_4431(config)#license feature hse
ISR_4431(config)#license feature hseck9 ?
<cr> <cr>
ISR_4431#license ri
ISR_4431#license right-to-use ?
move Move to permanent mode
ISR_4431#license right-to-use m
ISR_4431#license right-to-use move ?
WORD license name
ISR_4431#license right-to-use move hse
ISR_4431#license right-to-use move hseck9 ?
<cr> <cr>
ISR_4431#
what if you hit ENTER after:
then save and reload the device ?
Andrey.A
Hi all,
As this router is in production I can not do some testing on it. After searching through documentation I found this:
The HSECK9 feature does not have an evaluation license that converts to an RTU license after 60 days; a feature license must be obtained.
We will buy the license and activate it after that. Thank you all on help!
Andrey
Sure that is a good approach to get License from Cisco and Activate it.
BB
