ISR4431 licensing question
Minnesotakid
I have a question relating to ISR licensing on a few ISR4331s. I'm a bit new to the licensing on these, for forgive me if it's something obvious.
We purchased the router with a Securityk9 license froim our vendor. While the show license command shows me that I have a permanent security license, the show version command does not. Is this normal? Maybe a bug? I'm seeing this on 3 different routers.
I also had my vendor provide me with PAK keys for the Securityk9 package, which I activated and installed on two of the devices. I then rebooted the devices but the licensing outputs didn't change.
Below I've included both commands.
ISR4331#show version
Suite License Information for Module:'esg'
Suite                         Suite Current             Type Suite           Next reboot
FoundationSuiteK9  FoundationSuiteK9    EvalRightToUse    FoundationSuiteK9
securityk9
appxk9
AdvUCSuiteK9           None                      None                         None
uck9
cme-srst
cube
Technology Package License Information:
Technology         Technology-package     Technology-package
                           Current         Type              Next reboot
appxk9                   None           None                None
uck9                       None           None                None
securityk9               None           None                securityk9
ipbase                    ipbasek9     Permanent        ipbasek9
cisco ISR4331/K9 (1RU) processor with 1648789K/6147K bytes of memory.
ISR4331#show license
Index 1 Feature: appxk9
Period left: 4 weeks 6 days
Period Used: 3 weeks 4 days
License Type: EvalRightToUse
License State: Active, In Use
License Suite: FoundationSuiteK9
License Count: Non-Counted
License Priority: Low
Index 2 Feature: uck9
Period left: Not Activated
Period Used: 0 minute 0 second
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 3 Feature: securityk9
Period left: Life time
License Type: Permanent
License Priority: Medium
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
License Count: 0/0 (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
Index 10 Feature: internal_service
blwilkins1
Once you reboot, you will be good to go. Look here...
uck9                       None           None                None
And here...
@blwilkins1 I thought so as well, unfortunately, the router has been rebooted and the licensing output did not change.
Did you do a "wr mem" before rebooting?
I have the same issue, I did do a wr mem before rebooting, ive rebooted a couple times now without change in sh ver licenses showing, it still says it will show on next reboot there.
Do you know why this is happening?
