11-19-2024 09:15 AM
Hello All,
I have an ISR 4431 running Cisco IOS XE Software, Version 16.06.05 with NIM-ES2-8-P installed and would like to create a port channel to C9200 switch. is that something you can help me with and is it supported. Any examples on how to are appreciated.
BigK.
Solved! Go to Solution.
11-19-2024 10:19 AM
As per the Datasheet, this module does not support port-channel.
But, the configuration for Port-channel is simple. You can see here, just in case.
Table 3. New Features
Feature |
LAN Switch NIM |
New Feature |
10/100/1000BASE-TX |
ü |
ü |
IEEE 02.1Q Trunking |
ü |
IEEE 802.1D Spanning Tree |
ü |
Static and dynamic MAC address learning |
ü |
IEEE 802.1X port-based and multiple supplicant |
ü |
PoE (15.4W) |
ü |
PoE+ (30W) |
ü |
ü |
IEEE 802.1u (guest VLAN) |
ü |
IEEE 802.1s Multiple Spanning Tree (MST) |
ü |
IEEE 802.1w Rapid Spanning Tree Protocol (RSTP) |
ü |
IGMP Snooping |
ü |
Auxiliary VLANS |
ü |
Maximum number of VLANs supported |
60 |
ü |
Maximum number of VLAN IDs |
4094 |
SDWRR and fixed scheduling |
ü |
ü |
4 QoS queues per port |
ü |
ü |
IEEE 802.1p for 802.1q tagged packets |
ü |
Port-based priority for untagged packets |
ü |
Priority override |
ü |
Switched Port Analyzer (SPAN) |
ü |
SPAN across multiple NIMs |
Not supported |
Not supported |
Number of Spanning Tree Protocol instances |
1 per VLAN (60 maximum) |
Per-port storm control |
Not supported |
MAC notification |
ü |
Dynamic secure port |
Not supported |
Secure port filtering (port security) |
Not supported |
Intrachassis cascading (no external link between NIM cards) |
ü |
ü |
Private VLAN edge (protected port) |
ü |
ü |
Protected port (across multiple NIMs) |
ü |
ü |
Bridge protocol data unit (BPDU) guard |
ü |
PortFast |
ü |
Jumbo Frames |
ü |
VTP (client, server, and transparent modes) |
ü |
Per-VLAN Spanning Tree (PVST) |
ü |
Per-port power monitoring and policing |
ü |
ü |
Hot Standby Router Protocol (HSRP), Virtual Router Redundancy Protocol (VRRP), and Gateway Load Balancing Protocol (GLBP) on VLAN interfaces |
ü |
ü |
MGF integration |
ü |
CiscoWorks LAN Management Solution (LMS) |
ü |
RMON support |
ü |
Auto-MDIX |
ü |
Cisco EtherChannel technology |
Not supported |
11-19-2024 10:19 AM
Feature |
LAN Switch NIM |
New Feature |
ü |
ü |
ü |
ü |
ü |
ü |
PoE (15.4W) |
ü |
PoE+ (30W) |
ü |
ü |
ü |
ü |
ü |
IGMP Snooping |
ü |
Auxiliary VLANS |
ü |
60 |
ü |
4094 |
ü |
ü |
ü |
ü |
ü |
ü |
Priority override |
ü |
ü |
Not supported |
Not supported |
Not supported |
MAC notification |
ü |
Not supported |
Not supported |
ü |
ü |
ü |
ü |
ü |
ü |
ü |
PortFast |
ü |
Jumbo Frames |
ü |
ü |
ü |
ü |
ü |
ü |
ü |
MGF integration |
ü |
ü |
RMON support |
ü |
Auto-MDIX |
ü |
Not supported |
