Issue on 6500
Ali Norouzi
Hi All,
I have problem with my 6509-E. The card number on disbales and enables sequentialy every about 10 minutes. Below is list modules and then the logs:
rtr-019#sh module
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1048958X
  3    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL1031WPAY
  5    2  Supervisor Engine 720 (Hot)            WS-SUP720-BASE     SAD084600S8
  6    2  Supervisor Engine 720 (Active)         WS-SUP720-BASE     SAL1228X83G
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0019.5606.5448 to 0019.5606.545f   2.5   12.2(18r)S1  12.2(33)SXH7 Ok
  3  0018.73b8.5ec0 to 0018.73b8.5ec3   2.4   12.2(14r)S5  12.2(33)SXH7 Ok
  5  0011.21b9.bb74 to 0011.21b9.bb77   3.2   8.5(4)       12.2(33)SXH7 Ok
  6  000a.b86d.75f8 to 000a.b86d.75fb   4.0   8.5(4)       12.2(33)SXH7 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Distributed Forwarding Card WS-F6700-DFC3BXL   SAL1106G5KL  5.3    Ok
  3  Distributed Forwarding Card WS-F6700-DFC3BXL   SAL1051BJJ3  5.3    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3BXL     SAL1030WGRC  1.8    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAD083902XF  2.4    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3BXL     SAD09100DKU  1.4    Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL1228X6TH  3.1    Ok
Mod  Online Diag Status
  1  Pass
  3  Pass
  5  Pass
  6  Pass
IOS: s72033-adventerprisek9_wan-vz.122-33.SXH7.bin
04:39:49: %CPU_MONITOR-SP-6-NOT_HEARD: CPU_MONITOR messages have not been heard for 90 seconds [1/0]
04:40:19: %CPU_MONITOR-SP-6-NOT_HEARD: CPU_MONITOR messages have not been heard for 120 seconds [1/0]
04:38:23: %XDR-6-XDRIPCNOTIFY: Message not sent to slot 1/0 (1) because of IPC error timeout. Disabling linecard. (Expected during linecard OIR or system reloads)
Would you help me to find the root cause?
Richard Michael
Hello Ali,
IPC is the inter processer communication done by the IOS processors which happens via the EOBC.The above messages indicates that either RP or SP believes there is a problem with the peer device. SP will reset a LC if it does not hear CPU_MONITOR messages for > 150 seconds (default timeout value).
Can you please share the following commands to investigate this further,
sh heart
remote com sw sh heartbeat
sh ipc port
sh ipc session tx verbose
remote login switch
debug heartbeat
also I would also suggest you to do a manual switchover by entering the redundancy force-switchover command
and observe if this errors are appearing again in the switch.
Ricky Micky
*Rate if this is useful
Hello Richard,
Thank you for your reply. I attached your requested logs and outputs. Unfortunately after switching the SP the problem still exist.
Hi Ali,
There needs to be more investigations done with this SUP. Is it possible for you to open a TAC case?
Richard
Hi Richard,
Actually we don't have support contract and I can not open TAC case. Do you think the SUP has problem or the card? Currently a 10G card on this platform works fine.
Ali
