Issue routing traffic through my 2851 router
Eric Williamson
I'm trying something EXTREMELY simple. ISP-->Modem-->Cisco 2851 Router-->Cisco 3560 Switch-->end-user devices.
As of now I can browse to the internet IF configured as such: ISP-->Modem-->Wifi Router-->end user devices.....BUT I cannot browse if using the desired configuration above.
I have taken the liberty of troubleshooting and I've attached my configurations (I've x'd out a few IP's for confidentiality - these are the publicly routable IP's that are specific to my ISP where I live).
From my router I can reach the internet - but from my switch and end user devices I'm not getting out. When I connect up my WIFI router between the modem and the lab router (2851 listed above) I can remotely manage my router in my house but I cannot get out to the internet. I've watched youtube tutorials, reviewed my old CCNA/CCNP books, I know many people have successfully used their lab devices to do this before.....but at the risk of asking a silly question, WHAT AM I DOING WRONG????
One things worthy of note: when I turn on "debug ip routing" I get this message across the screen periodically:
RT: NET-RED 0.0.0.0/0
My default static route and gateway of last resort has been configured.
LAN-wise I'm good, but WAN connectivity for the switch and end-user devices is just not there. I'm out of ideas at this point.
Can someone please help - or just poor cold water on me and find my silly mistake because I've been at this for a while and I'm outta gas.
Attached is my config files and troubleshooting steps. BTW...I've rebooted the modem, write-erased the switch and router countless times, taken off ip-source-routing, ip cef.....not that that should matter here, but I've tried this multiple ways.
Eric
ALSO......I've tried setting up "ip nat inside" on all my sub-interfaces AND I've tried to just get rid of NAT all together.
I'm completely out of ideas.  See configuration attached.
Daniel Boling
Eric,
You do have to have ip nat inside configured in your subinterfaces.
Let's narow this down a bit.  Have (at least) the following configured:
interface GigabitEthernet0/0
Ip address dhcp
ip nat outside
no shutdown
interface GigabitEthernet0/1
no ip address
no shutdown
interface GigabitEthernet0/1.16
encapsulation dot1Q 16
ip address 192.168.15.1 255.255.255.0
ip nat inside
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 192.168.16.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 dhcp
Try:
Router# ping 8.8.8.8
Assuming you get a successful reply, please try this:
Router# ping 8.8.8.8 source 192.168.16.1
Do you get a reply?
