Issue when set up snmp on cisco firewal
loc.nguyen
I got warning when I tried to set up snmp on a FTD:
fw1/pri/act(config)# snmp-server host inside 10.x.x.241 community xxxx version 2
WARNING: mapped-address 10.x.x.250/161 overlaps with existing static NAT in Section 1, rule 7.
WARNING: mapped-address 216.y.y.36/161 overlaps with existing static NAT in Section 1, rule 7.
fw1/pri/act(config)#fw1/pri/act(config)# snmp-server host inside 10.x.x.241 community xxxx version 2
Do you know why it happens and how to fix that?
Note: The snmp doesn't work after  setting up.
Loc
