Is it possible to use QoS for customers traffic on PE core int ?
gongya001
I have the following ingress packet on PE core facing interface from one customer. Should I use exp from mpls header or dscp in ip header ?
thanks !!
Joseph W. Doherty
According to Cisco documentation:
  • If a packet is encapsulated in MPLS, the MPLS payload cannot be checked for other protocols such as IP for classification or marking. Only MPLS EXP marking affects packets encapsulated by MPLS.
From: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_classn/configuration/xe-3s/qos-classn-xe-3s-book/qos-classn-mrkg-mpls-exp.html
Joseph W. Doherty
thanks so much !!
