Issue with Equal Cost Static Default Routes
denny.lee
Question:
I'm trying to troubleshoot an issue with equal cost static default routes. Here is the configuration of the 3560:
interface FastEthernet0/1
no switchport
ip address 8.8.8.1 255.255.255.0
interface FastEthernet0/2
no switchport
ip address 9.9.9.1 255.255.255.0
interface Vlan1
ip address 50.50.50.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 8.8.8.2
ip route 0.0.0.0 0.0.0.0 9.9.9.2
"show ip route" output
Gateway of last resort is 9.9.9.2 to network 0.0.0.0
50.0.0.0/24 is subnetted, 1 subnets
C 50.50.50.0 is directly connected, Vlan1
8.0.0.0/24 is subnetted, 1 subnets
C 8.8.8.0 is directly connected, FastEthernet0/1
9.0.0.0/24 is subnetted, 1 subnets
C 9.9.9.0 is directly connected, FastEthernet0/2
S* 0.0.0.0/0 [1/0] via 9.9.9.2
[1/0] via 8.8.8.2
I'm pinging 4 different IPs out in the cloud with two equal cost default routes configured on a 3560. The IPs that I'm trying to ping are 1.1.1.1, 2.2.2.2, 3.3.3.3, and 4.4.4.4 - sourcing from 50.50.50.50. However, when I ping all four IP simutaneously it only egresses the 8.8.8.0 gateway.
I've used the "show ip cef exact-route" output. Which looks like it should distribute the load based on destination.
Switch#sh ip cef exact-route 50.50.50.1 1.1.1.1
50.50.50.1 -> 1.1.1.1 => IP adj out of FastEthernet0/1, addr 8.8.8.2
Switch#sh ip cef exact-route 50.50.50.1 2.2.2.2
50.50.50.1 -> 2.2.2.2 => IP adj out of FastEthernet0/1, addr 8.8.8.2
Switch#sh ip cef exact-route 50.50.50.1 3.3.3.3
50.50.50.1 -> 3.3.3.3 => IP adj out of FastEthernet0/2, addr 9.9.9.2
Switch#sh ip cef exact-route 50.50.50.1 4.4.4.4
50.50.50.1 -> 4.4.4.4 => IP adj out of FastEthernet0/1, addr 8.8.8.2
"show ip cef" output
Switch#sh ip cef
Prefix Next Hop Interface
0.0.0.0/0 8.8.8.2 FastEthernet0/1
9.9.9.2 FastEthernet0/2
"traceroute" output
Tracing the route to 1.1.1.1
1 8.8.8.2 0 msec
9.9.9.2 0 msec
8.8.8.2 0 msec
Any thoughts to why it only goes out one gateway and not both based on the cef table?
Edison Ortiz
Denny,
Your equal cost static routing is working but the result is not showing as expected since you are doing it from the switch itself.
Best to setup a couple of clients in Vlan1 targeting different destinations to see the full effect.
__
Edison.
I've tried this from several different hosts connected to the switch with the same results.
From the traceroute you've shown, it's displaying the load-balancing taking effect.
__
Edison.
Yeah. That was the output from the switch and how packets should be traversing to the respective destinations. Testing is a different story altogether. Once I have multiple hosts connected to the switch each simultaneously pinging all the hosts mentioned - all traffic leaves one interface.
