Issue with IOS for CME 9.5 and 2951 router
c.holloway
Good morning everyone!
I'm having an issue with a 2951 ISR upon which I'm trying to load the IOS for CME 9.5.  I had no issues loading the IOS on to the device but it consistantly fails on boot.  Here is what I see on the console during the boot process
System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 2010 by cisco Systems, Inc.
Total memory size = 512 MB - DIMM0 = 512 MB, DIMM1 = 0 MB
CISCO2951/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x4000000, size: 0x18fa0
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x4000000, size: 0x5a5eb44
Self decompressing the image : ##############################################################################################
####################################################################################################### [OK]
*** Alignment Error Exception ***
PC = 0x0, Vector = 0x600, SP = 0x1ffffde0
monitor: command "boot" aborted due to exception
In looking at this, it seems as though the IOS image checks out. I erased and readded a couple of times to make sure the image wasn't corrupt, this image was pulled off of another 2951 router that is currently running it without issues.
I have also double checked the hardware in the device and there are not currently any add-in cards that could account for this error.
Any thought?
5 Replies 5
paolo bevilacqua
Faulty router, contact TAC for replacement.
Other IOS versions work just fine though. I can run both:
c2951-universalk9-mz.SPA.152-3.T3.bin (CME 9.0)
c2951-universalk9-mz.SPA.151-4.M4.bin (CME 8.6)
What leads you to believe the hardware itself is faulty?
That is really for the TAC to clarify.
OH OK just your best guess then.  I thought I was missing something obvious and was curious what it was
You can try updating rommon. But that's pretty much all you can do about something that has no evident explanation.
