Issue with IP SLA failover and OSPF/Static redistribution
Venky
We have 2 locations. Each location is having one ISP, one firewall and Cisco 9500 switch. Both locations are connected via backbone network with 10G P2P connection. I implemented IP SLA on both sides to track icmp and failover to other location if track is down. But even after ISP is back up at testing location, sites traffic is still trying to use other location. Initially I saw ping that I used in track are using different path to go out and I blocked it on firewall. But even after blocking, I think 9500 is thinking it is still active. I'm confused on what to block in advertisement.
All remote locations terminate at Location 1 9500 switch and Location 1 is having 10 G pipe to Location 2. I was in assumption that track at Location 1 fails, it should switch to Location 2 based on ip route which is working fine. But fail back is not happeing.
Location 1 :-
track 8 ip sla 1 reachability
ip sla 1
icmp-echo 75.75.75.75 source-ip 10.168.2.1          ***interface IP on switch directly connected to Firewall***
ip sla schedule 1 life forever start-time now
router ospf 1
router-id 10.104.104.40
redistribute connected subnets
redistribute static subnets
network 10.104.104.0 0.0.0.255 area 0
network 10.10.0.252 0.0.0.3 area 0                                               ***backbone network***
network 10.168.2.0 0.0.0.15 area 0        ***OSPF network to firewall****
default-information originate                       ****remote locations to get default route connected only to this locations****
ip route 0.0.0.0 0.0.0.0 10.168.2.14 track 8
ip route 0.0.0.0 0.0.0.0 10.10.0.253 10
Location 2 :-
ip sla 1
icmp-echo 4.2.2.2 source-ip 10.168.2.17             ***this IP is on switch directly connected to firewall**
router ospf 1
router-id 10.201.20.200
network 10.10.0.252 0.0.0.3 area 0          **between locations***
network 10.168.2.16 0.0.0.15 area 0         *Interconnect VLAN between switch and firewall***
ip route 0.0.0.0 0.0.0.0 10.168.2.30 track 8
ip route 0.0.0.0 0.0.0.0 10.10.0.254 10
I believe some filtering has to be done but not sure where to do.
10 Replies 10
with IP SLAs, it usually a good idea to configure a static route towards the IP address your are pinging. In your case that means:
Location 1
ip route 75.75.75.75 255.255.255.255 10.168.2.14
Location 2
ip route 4.2.2.2 255.255.255.255 10.168.2.30
What are you redistributing ? Post the full configs of both sides...
Solution seems to be working fine but this route is also being redistributed in OSPF process due to which firewall is sending back it on to the same interface.
Is there a way to block advertising this static route and advertise all other static routes into OSPF process ?
I was thinking about using distribution list to filter but I haven't done it before. If you can help that would be great. Thank you so much again for responding.
Venky
above configured on both sides in OSPF process. There are some internal networks which I removed. There is nothing special config than this.
Hello
ip sla 1
What is possibly occurring is the tracked ip address is reachable via the secondary path as such the track is failing.
what you need to do is negate the tracked ip from being reached via the other path.
ip route 75.75.75.75 255.255.255.255 null 0 2
Kind Regards
Paul
Thank paul, this will work but this ip route will be redistributed into OSPF process we have redistribute commands under OSPF process. I need a way to block this specific ip route advertisement in OSPF process leaving all other routes advertised.
Hello
ip prefix-list 10 deny x.x.x.x/32
ip prefix-list 10 permit 0.0.0.0/0 le32
route-map static
match ip address prefix-list 10
router ospf xx
redistribute static route-map static subnets
sent from iphone
Kind Regards
Paul
just a thought, but you can also use EEM scripts to cause the failover. The scripts would look like below:
Location 1
interface GigabitEthernet0/0
description Location 1 Link to ISP
ip address 10.168.2.1 255.255.255.0
interface GigabitEthernet0/1
description Link to Location 2
ip address 10.10.0.253 255.255.255.252
event manager applet SHUT_INT
even track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "interface GigabitEthernet0/0"
action 4.0 cli command "shut"
action 5.0 cli command "exit"
action 6.0 cli command "interface GigabitEthernet0/1"
action 7.0 cli command "no shut"
action 8.0 cli command "end"
event manager applet NO_SHUT_INT
even track 1 state up
action 4.0 cli command "no shut"
action 7.0 cli command "shut"
Location 2
description Location 2 Link to ISP
ip address 10.168.2.17 255.255.255.0
description Link to Location 1
ip address 10.10.0.254 255.255.255.252
Hello
@Georg Pauwen  even though the script would be applicable it’s still tied to the ip sla tracking and this would probably fail due the the tracking seeing the tracked ip via its alternative path thus is won’t failover correctly
Kind Regards
Paul
With the script, there would never be an alternative path. The interface towards the other location would be 'shut'. That's the idea.
Hello
Yes but for the eem script to work correctly it’s tied to ip sla tracking which relies on the reachability of the tracked ip
The tracked ip would be reachable via the either default static which you wouldn’t want to happen.
Kind Regards
Paul
