NAT
myates123
I cant get my laptops to connect outside their particular LAN.
I did a ip nat outside for the trunks attached to the router, example eth3/0. None of the links on the switch to the laptop fa0/2, fa0/1, fa0 allow to be marked as "ip nat inside"
I was able to mark all the trunks attached to the router as outside, but everything switch to the laptop dont allow to be marked as inside.
Please advise! Thank you so much!
Hello
Most switches don’t support NAT only high end platforms do so you will need a router to perform this function
Kind Regards
Paul
in addition to Paul's post, it looks like you are doing this in Packet Tracer ? Packet Tracer has some limitations as well...can you post the (zipped) Packet Tracer project (.pkt) file ?
