Issue with L2TPV3
Star_blazer
Visitor
On our side we using:
Cisco IOS Software, 3700 Software (C3725-ADVENTERPRISEK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
Config:
pseudowire-class ether-pw
encapsulation l2tpv3
ip local interface FastEthernet0/0
ip pmtu
interface FastEthernet0/1.111
encapsulation dot1Q 111
ip virtual-reassembly max-fragments 64 max-reassemblies 1024
no cdp enable
xconnect 193.193.***.*** 123 encapsulation l2tpv3 pw-class ether-pw
end
no ip address
ip access-group 101 in
no ip proxy-arp
ip accounting output-packets
load-interval 30
duplex auto
speed auto
no keepalive
no cdp enable
end
CiscoRouter#show l2tun session
%No active L2F tunnels
L2TP Session Information Total tunnels 1 sessions 1
LocID RemID TunID Username, Intf/ State Last Chg Uniq ID
Vcid, Circuit
296** 171699**** 542** 123, Fa0/1.111:111 est 00:24:47 3**
%No active PPTP tunnels
So the thing is other side can ping my host, but with huge loss (8 packets lost, 1 ok) and have some pure access to http.
But i can't ping host on their side(double checked firewalls etc) .
ip cef enabled.
I tried to attach xconnect to Fa0/1 which is the interface that look into LAN. But it is the same.
Can someone help me?
Ok, this problem resolved.
Steps:
1) We changed ios from other side 15 -> 12.xx (CIsco 2800).
2) I changed configuration to forward traffic through Loopback interfaces. So there are GRE Tunnel to provide connection between them.
This works pretty ok.
Our GW
Tunnel to loopbacks
interface Tunnel5
ip address 192.168.50.1 255.255.255.0
ip mtu 1476
ip tcp adjust-mss 1360
tunnel source FastEthernet0/0
tunnel destination xxx.xxx.xxx.xxx (other side WAN)
end
interface Loopback0
ip address 192.168.10.10 255.255.255.0
end
ip route 0.0.0.0 0.0.0.0 (wan addr)
ip route 192.168.20.0 255.255.255.0 192.168.50.2
L2TPv3
vlan database
vtp transparent
vlan 111 name TUNNEL-L2TPv3-v200
configure terminal
ip cef
l2tp-class L2TP-CLASS1
hidden
authentication
hello 30
password xxx
pseudowire-class PW-CLASS1
sequencing both
protocol l2tpv3 L2TP-CLASS1
ip local interface Loopback0
ip pmtu
ip dfbit set
ip tos reflect
interface Fa0/1.111
description *** L2TP Tunnel to xxx ***
xconnect 192.168.20.20 111 pw-class PW-CLASS1 sequencing both
snmp-server enable traps l2tun session
Other GW
Tunnel to loopbacks
interface Tunnel5
ip address 192.168.50.2 255.255.255.0
ip mtu 1476
tunnel destination (wan addr)
end
interface Loopback0
ip address 192.168.20.20 255.255.255.0
end
ip route 0.0.0.0 0.0.0.0 wan addr
ip route 192.168.10.0 255.255.255.0 192.168.50.1
L2TPv3
vlan database
vtp transparent
configure terminal
ip cef
hidden
authentication
hello 30
password xxx
sequencing both
ip pmtu
ip dfbit set
ip tos reflect
interface Fa0/1.111
description *** L2TP Tunnel to xxx***
xconnect 192.168.10.10 111 pw-class PW-CLASS1 sequencing both
Giuseppe Larosa
Hello Star_blazer,
if the other side can ping the fa0/0 IP addres with 80% of loss I would say that you have a connectivity problem in the path.
You need to verify if L2TPv3 protocol is allowed on the path too.
see
https://tools.ietf.org/html/rfc3931
You need to allow IP protocol 115 L2Tpv3 does not use UDP like L2TPv2 did
L2TPv3 over IP (both versions) utilizes the IANA-assigned IP protocol
   ID 115.
 section 4.1.1  of the RFC
Hope to help
Giuseppe
Steps:
Our GW
Tunnel to loopbacks
interface Tunnel5
ip mtu 1476
end
interface Loopback0
end
L2TPv3
vlan database
vtp transparent
configure terminal
ip cef
hidden
authentication
hello 30
password xxx
sequencing both
ip pmtu
ip dfbit set
ip tos reflect
interface Fa0/1.111
Other GW
Tunnel to loopbacks
interface Tunnel5
ip mtu 1476
end
interface Loopback0
end
L2TPv3
vlan database
vtp transparent
configure terminal
ip cef
hidden
authentication
hello 30
password xxx
sequencing both
ip pmtu
ip dfbit set
ip tos reflect
interface Fa0/1.111
