Issue with levels of console access
GWoodcock
Hi all,
I'm trying to wipe some old devices remotely and run into an issue.
I am connected to a remote 4451 router and through the Aux I am connected to a 3945 with several hardware modules.
To wipe those modules I need to go through the 3945 backplane via the service module session command.
But when I try to get out of the module via (Ctrl+alt+6) X I end up back at the 4451.  Even after clearing the line and connecting again the 3945 passes the connection to the service module and I can't get back to the 3945.
If there another commend that will get me from the service-module to the 3945 without going back to the 4451?
4451
| via Aux
3945
| via backplane
Service-module
Cheers
Type your ctrl command sequence twice before you type the X. That should get you out of the service module and back to the router.
Rick
Rick
5 Replies 5
just to make sure: are you using control+shift+6 x ? In your post you wrote Ctrl+alt+6 X...
Rick
Rick
Thanks Rick, typing the first sequence twice before the X worked perfectly
You are welcome. I am glad that my suggestion was helpful.Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
Rick
Sorry I meant shift not alt, as mentioned above I was doing it correctly as I was cancelling the session and returning to the 4451.
