Issue with Routing over Dynamic VTI
ntalbot91
In my lab, I have a Dynamic VTI established between two routers. I'm exchanging routes via bgp between the two routers.  Off my Branch VPN router (VPN1), I have a router(Node8) with a loopback and a point-to-point interface to the VPN1. My DVTI is up, and I can ping networks that are directly connected to the routers. I'm unable to ping anything off the routers even though I'm exchanging routes successfully. After looking at pcaps, it appears the return traffic is not getting re-encrypted on the branch router.
Ping from MVPN1 to VPN1:
mvpn1#ping 172.16.25.2 source loopback 500
Sending 5, 100-byte ICMP Echos to 172.16.25.2, timeout is 2 seconds:
Packet sent with a source address of 192.168.1.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/43/52 ms
Ping from MVPN1 to Node8:
mvpn1#ping 172.16.25.1 source loopback 500
Sending 5, 100-byte ICMP Echos to 172.16.25.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Capture on VPN1 ETH1/0 interface:
My topology:
VPN1 is the branch vpn router and MVPN1 is the remote router. Router Hotspot is supposed to emulate a mobile hotspot performing NAT and DHCP. I'm translating the eth1/1 interface of MVPN1 to 8.8.8.8.
Configs:
VPN1:
crypto ikev2 proposal PROP
encryption aes-cbc-128
integrity sha256
group 19
crypto ikev2 policy POLICY
proposal PROP
crypto ikev2 profile PROFILE
match certificate mycertmap
identity local dn
authentication remote rsa-sig
authentication local rsa-sig
pki trustpoint CA
dpd 30 10 periodic
aaa authorization group cert list default default
virtual-template 1
crypto ipsec transform-set TS esp-aes esp-sha256-hmac
mode tunnel
crypto ipsec profile IPSEC_PROFILE
set transform-set TS
set ikev2-profile PROFILE
responder-only
interface Virtual-Template1 type tunnel
ip unnumbered Loopback500
tunnel source Ethernet1/1
tunnel mode ipsec ipv4
tunnel destination dynamic
tunnel protection ipsec profile IPSEC_PROFILE shared
end
router eigrp 100
network 172.16.1.0 0.0.0.255
network 172.16.25.0 0.0.0.255
redistribute bgp 6128 metric 100000 10 255 1 1500
router bgp 6128
bgp log-neighbor-changes
redistribute eigrp 100
neighbor 5.5.5.5 remote-as 3128
neighbor 5.5.5.5 ebgp-multihop 2
neighbor 5.5.5.5 distribute-list deny_1918 out
neighbor 192.168.1.2 remote-as 65535
neighbor 192.168.1.2 ebgp-multihop 255
neighbor 192.168.1.2 soft-reconfiguration inbound
MVPN1:
integrity sha256
group 19
proposal PROP
identity local dn
pki trustpoint CA
dpd 30 10 periodic
mode tunnel
interface Tunnel1
tunnel destination 1.1.1.1
end
router bgp 65535
network 25.25.25.25 mask 255.255.255.255
network 172.16.1.0 mask 255.255.255.0
neighbor 192.168.1.1 remote-as 6128
neighbor 192.168.1.1 ebgp-multihop 255
neighbor 192.168.1.1 next-hop-self
Node8
router eigrp 100
network 172.16.26.0 0.0.0.255
Show Commands:
VPN1:
VPN1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is 5.5.5.5 to network 0.0.0.0
B* 0.0.0.0/0 [20/0] via 5.5.5.5, 01:31:05
1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 1.1.1.0/30 is directly connected, Ethernet1/1
L 1.1.1.1/32 is directly connected, Ethernet1/1
5.0.0.0/32 is subnetted, 1 subnets
S 5.5.5.5 [1/0] via 1.1.1.2
7.0.0.0/24 is subnetted, 1 subnets
B 7.7.7.0 [20/0] via 5.5.5.5, 01:30:48
8.0.0.0/24 is subnetted, 1 subnets
B 8.8.8.0 [20/0] via 5.5.5.5, 01:30:48
172.16.0.0/16 is variably subnetted, 4 subnets, 2 masks
B 172.16.1.0/24 [20/0] via 192.168.1.2, 00:11:24
C 172.16.25.0/24 is directly connected, Ethernet1/0
L 172.16.25.2/32 is directly connected, Ethernet1/0
D 172.16.26.1/32 [90/409600] via 172.16.25.1, 00:03:01, Ethernet1/0
192.168.1.0/24 is variably subnetted, 3 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Loopback500
L 192.168.1.1/32 is directly connected, Loopback500
S 192.168.1.2/32 is directly connected, Virtual-Access1
192.168.10.0/32 is subnetted, 1 subnets
C 192.168.10.1 is directly connected, Loopback10
VPN1#show crypto ikev2 sa
IPv4 Crypto IKEv2 SA
Tunnel-id Local Remote fvrf/ivrf Status
1 1.1.1.1/4500 8.8.8.8/4500 none/none READY
Encr: AES-CBC, keysize: 128, Hash: SHA256, DH Grp:19, Auth sign: RSA, Auth verify: RSA
Life/Active Time: 86400/1809 sec
VPN1#show crypto ipsec sa
interface: Virtual-Access1
Crypto map tag: Virtual-Access1-head-0, local addr 1.1.1.1
protected vrf: (none)
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
current_peer 8.8.8.8 port 4500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 96, #pkts encrypt: 96, #pkts digest: 96
#pkts decaps: 105, #pkts decrypt: 105, #pkts verify: 105
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 1.1.1.1, remote crypto endpt.: 8.8.8.8
path mtu 1500, ip mtu 1500, ip mtu idb Ethernet1/1
current outbound spi: 0x411F081D(1092552733)
PFS (Y/N): N, DH group: none
inbound esp sas:
spi: 0xD6C37685(3603134085)
transform: esp-aes esp-sha256-hmac ,
in use settings ={Tunnel UDP-Encaps, }
conn id: 3, flow_id: 3, sibling_flags 80000040, crypto map: Virtual-Access1-head-0
sa timing: remaining key lifetime (k/sec): (4302810/1691)
IV size: 16 bytes
replay detection support: Y
Status: ACTIVE(ACTIVE)
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 4, flow_id: 4, sibling_flags 80000040, crypto map: Virtual-Access1-head-0
sa timing: remaining key lifetime (k/sec): (4302825/1691)
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
MVPN1:
mvpn1#show ip route
Gateway of last resort is 10.1.1.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.1.1.1
B 7.7.7.0 [20/0] via 192.168.1.1, 00:11:34
B 8.8.8.0 [20/0] via 192.168.1.1, 00:11:34
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.1.1.0/24 is directly connected, Ethernet1/1
L 10.1.1.2/32 is directly connected, Ethernet1/1
C 172.16.1.0/24 is directly connected, Loopback600
L 172.16.1.1/32 is directly connected, Loopback600
B 172.16.25.0/24 [20/0] via 192.168.1.1, 00:11:34
B 172.16.26.1/32 [20/409600] via 192.168.1.1, 00:02:41
S 192.168.1.1/32 is directly connected, Tunnel1
L 192.168.1.2/32 is directly connected, Loopback500
mvpn1#show crypto ikev2 sa
1 10.1.1.2/4500 1.1.1.1/4500 none/none READY
Life/Active Time: 86400/1842 sec
IPv6 Crypto IKEv2 SA
mvpn1#show crypto ipsec sa
interface: Tunnel1
Crypto map tag: Tunnel1-head-0, local addr 10.1.1.2
current_peer 1.1.1.1 port 4500
#pkts encaps: 102, #pkts encrypt: 102, #pkts digest: 102
#pkts decaps: 93, #pkts decrypt: 93, #pkts verify: 93
local crypto endpt.: 10.1.1.2, remote crypto endpt.: 1.1.1.1
current outbound spi: 0xD6C37685(3603134085)
inbound esp sas:
conn id: 4, flow_id: 4, sibling_flags 80000040, crypto map: Tunnel1-head-0
sa timing: remaining key lifetime (k/sec): (4367379/1748)
IV size: 16 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 3, flow_id: 3, sibling_flags 80000040, crypto map: Tunnel1-head-0
sa timing: remaining key lifetime (k/sec): (4367391/1748)
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
Node8:
Show ip route:
D*EX 0.0.0.0/0 [170/284160] via 172.16.25.2, 00:00:16, Ethernet1/0
D EX 7.7.7.0 [170/284160] via 172.16.25.2, 00:00:16, Ethernet1/0
D EX 8.8.8.0 [170/284160] via 172.16.25.2, 00:00:16, Ethernet1/0
D EX 172.16.1.0/24 [170/284160] via 172.16.25.2, 00:00:16, Ethernet1/0
L 172.16.25.1/32 is directly connected, Ethernet1/0
C 172.16.26.1/32 is directly connected, Loopback0
Hey Paul,
Thanks for your reply. I was completely out of ideas last night, and I decided to go ahead, and migrate my routers from a dynamip 7200 image to an IOL image, and after doing that everything is working as expected. I made no other changes to my configs. My guess is it was some kind of bug in the dynamips image I was running.
Hello
It doesseem that your routing is being propergated correctly - Can you post from
VPN and Node 8 :
sh ip protocols
sh ip access-list
MVPN1
traceroute 172.16.25.2 source loopback 500 numeric
traceroute 172.16.25.1 source loopback 500 numeric
Node8
traceroute 172.16.1.1 source loopback 0 numeric
traceroute 172.16.1.1 source eth1/0 numeric
Kind Regards
Paul
Hey Paul,
Hello
Glad to hear you got it working.
Kind Regards
Paul
