Issues with Access-list on 2911 Router with VPN / remote access
lars.arler
Hi and thanks in advance
My 2911 Router is running ok !!
But I would like to put some more security on the WAN Interface on the inbound side.
But I struggle a little on how to set up the ACL - Every time I assign the ACL to the WAN interface my connection to the outside (the internet) stops on inside networks..
- any clues on what I’m doing wrong ??
So this is what I like to achieve :
  1. Only allow (DNS, WWW, IMAP, SMTP & VPN remote access) coming in the WAN interface..
  2. All networks on the inside will have access to the outside..
How do I make sure that I don't shout down the VPN remote access .
Hav I all the right ports
- any special things to be aware off ??
Her is my setup ( ACL + WAN Int )
access-list 1 permit 192.168.100.0 0.0.0.225
access-list 1 permit 192.168.50.0 0.0.0.255
access-list 150 remark ## WWW - SMTP - IMAP - FTP - DOMAINE - VPN ##
access-list 150 permit udp any any eq domain
access-list 150 permit udp any eq domain any
access-list 150 permit tcp any any eq domain
access-list 150 permit tcp any eq domain any
access-list 150 permit tcp any any eq www
access-list 150 permit tcp any any eq 8080
access-list 150 permit tcp any any eq 443
access-list 150 permit tcp any any eq 587
access-list 150 permit tcp any any eq 143
access-list 150 permit tcp any any eq ftp-data
access-list 150 permit udp any any eq rip
access-list 150 permit igmp any any
access-list 150 permit eigrp any any
access-list 150 permit udp any any eq isakmp
access-list 150 permit udp any any eq 1000
access-list 150 permit udp any any eq 10000
access-list 150 permit udp any any eq non500-isakmp
access-list 150 permit udp any any eq 50
access-list 150 permit tcp any any eq 10000
----------------------- zip -----------------------
interface GigabitEthernet0/0
 description ISP WAN (Wide Area Network)
 ip address X.X.X.X 255.255.255.252
 ip access-group 150 in
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
Here is my running config
version 15.2
hostname R2911
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.154-3.M.bin
boot-end-marker
! card type command needed for slot/vwic-slot 0/2
no logging console
enable secret 5 XXXX
aaa new-model
aaa authentication login userauthen local
aaa authorization network userauthen local
aaa session-id common
memory-size iomem 25
no ipv6 cef
no ip source-route
ip dhcp excluded-address 192.168.100.1 192.168.100.49
ip dhcp excluded-address 192.168.50.1 192.168.50.49
ip dhcp pool VLAN200
 network X.X.X.X  255.255.255.240
 default-router X.X.X.X
 dns-server 8.8.8.8 4.4.4.4
ip dhcp pool VLAN100
 network 192.168.100.0 255.255.255.0
 default-router 192.168.100.1
 dns-server 192.168.100.1
ip dhcp pool VLAN50
 network 192.168.50.0 255.255.255.0
 default-router 192.168.50.1
 dns-server 192.168.50.1
ip domain name XXXX
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip name-server 62.243.0.166
ip name-server 194.192.207.166
ip cef
ip cef accounting non-recursive
crypto pki trustpoint TP-self-signed-XXXXXX
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-XXXXXX
 revocation-check none
 rsakeypair TP-self-signed-XXXXXX
crypto pki certificate chain TP-self-signed-XXXXXX
 certificate self-signed 01
  Xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  quit
voice-card 0
license feature snasw
license udi pid CISCO2911/K9 sn XXXXXXXXX
license accept end user agreement
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
hw-module pvdm 0/1
username XXXX password 0 XXX
username XXXX privilege 15 secret 5 XXXX
redundancy
ip ssh time-out 30
crypto isakmp policy 150
 encr aes 256
 authentication pre-share
 group 2
crypto isakmp client configuration group XXXX
 key XXXX
 dns 208.67.222.222 208.67.220.220
 pool REMOTE-VPN-CLIENTS
crypto isakmp profile XXXX-PROFILE
   match identity group XXXX
   client authentication list userauthen
   isakmp authorization list userauthen
   client configuration address initiate
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set XXXX esp-aes 256 esp-sha-hmac
crypto ipsec profile XXXX-VTUNNEL-PROFILE
 set security-association lifetime kilobytes disable
 set security-association lifetime seconds 86400
 set transform-set XXXX
 set isakmp-profile XXXX-PROFILE
interface Loopback0
 ip address x.x.x.x 255.255.255.0
interface Embedded-Service-Engine0/0
 no ip address
 ip nat outside
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN (Local Area Network)
 ip address pool VLAN100
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address pool VLAN50
 ip nat inside
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
interface FastEthernet0/1/0
 switchport access vlan 200
 no ip address
interface FastEthernet0/1/1
 no ip address
interface FastEthernet0/1/2
 no ip address
interface FastEthernet0/1/3
 no ip address
interface Virtual-Template1 type tunnel
 ip unnumbered GigabitEthernet0/0
 tunnel source GigabitEthernet0/0
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile XXXX-VTUNNEL-PROFILE
interface Vlan1
 no ip address
interface Vlan50
 description GUEST NETWORK DHCP POOL
 no ip address
 ip helper-address x.x.x.x
 ip nat inside
interface Vlan100
 description INTERNAL NETWORK DHCP POOL
 ip address dhcp
 ip nat inside
interface Vlan200
 description HWIC-4ESW_LAN - SERVER PARK
 ip address x.x.x.x 255.255.255.224
 ip nat inside
router eigrp 100
 network 80.0.0.0
 network 87.0.0.0
 network 192.168.0.0
router ospf 123
 network 80.0.0.0 0.255.255.255 area 0
 network 87.0.0.0 0.255.255.255 area 0
 network 192.0.0.0 0.255.255.255 area 0
ip local pool REMOTE-VPN-CLIENTS x.x.x.x. x.x.x.x
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 x.x.x.x
no cdp run
control-plane
mgcp profile default
gatekeeper
 shutdown
telephony-service
 max-ephones 10
 max-conferences 8 gain -6
 transfer-system full-consult
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 transport input ssh
line vty 5 15
 transport input ssh
scheduler allocate 20000 1000
end
2 Accepted Solutions
Seb Rupik
Hi there,
For the most part you have your ports defined in the wrong part of the ACL. Remember you are placing the ACL INbound, so you section relating to WWW, DOMAIN, etc will require the known port to be specified at the source port and the destination port will be a ephemeral port (so best left undefined, ie any). So you will have:
access-list 150 permit tcp any eq www any
access-list 150 permit tcp any eq 8080 any
access-list 150 permit tcp any eq 443 any
Since you are implementing this on a router you should really take the time to implement ZBF which will then handle this return traffic dynamically without you needing to configure it explicitly.
https://www.cisco.com/c/en/us/support/docs/security/ios-firewall/98628-zone-design-guide.html
cheers,
Seb.
Was the remote access VPN working before the ACL change??
Assuming you are using a VPN 'full tunnel' then you need to add ip nat inside to your virtual-template 1 and also specify the remote VPN address pool in access-list 1 so that it gets translated.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
Thanks Seb !!!
Your pointers regarding ANY ANY point taken ;-)
It solved the issue about the inside network having access to the outside (internettet) THANKS !!
But now my VPN (remote access) can't access the outside (internet) any clue  ??
Will ZBF solve that issue ??
I will look into ZBF as soon as possible
Her is my new ACL:
Extended IP access list 111
    10 permit udp any eq domain any (63 matches)
    20 permit tcp any eq domain any
    30 permit tcp any eq www any (51 matches)
    40 permit tcp any eq 8080 any
    50 permit tcp any eq 443 any (4206 matches)
    60 permit tcp any eq 587 any
    70 permit tcp any eq 143 any
    80 permit tcp any eq ftp-data any
    90 permit tcp any eq ftp any
    100 permit tcp any eq 10000 any
    110 permit udp any eq isakmp any (11 matches)
    120 permit udp any eq 10000 any
    130 permit udp any eq 50 any
    140 permit udp any eq non500-isakmp any
    150 permit udp any eq 1000 any
    160 permit udp any eq rip any
cheers,
Seb.
Tanks a lot Seb ;-)
It was the IP NAT INSIDE to the VIRTUAL-TEMPLATE 1 TYPE TUNNEL there was missing
