Issues with Hairpin NAT
hirani89
Here is my config. I am not able to access 192.168.30.3 when in the network. It works fine when connecting from outside.
Also, I can ssh using public IP when in the network and from outside. having issues with 192.168.30.3
Building configuration...
Current configuration : 5979 bytes
! Last configuration change at 08:40:03 UTC Sun Apr 18 2021 by root
version 15.1
hostname RRouter
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
ip dhcp excluded-address 192.168.10.1 192.168.10.50
ip dhcp excluded-address 192.168.20.1 192.168.20.50
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp excluded-address 192.168.10.101 192.168.10.254
ip dhcp excluded-address 192.168.101.1 192.168.101.10
ip dhcp excluded-address 192.168.30.1 192.168.30.50
ip dhcp excluded-address 192.168.40.1 192.168.40.10
ip dhcp pool ONE
 network 192.168.1.0 255.255.255.0
 dns-server 192.168.10.1
 default-router 192.168.1.1
ip dhcp pool TEN
 network 192.168.10.0 255.255.255.0
 dns-server 1.1.1.1 1.0.0.1
 default-router 192.168.10.1
ip dhcp pool TWENTY
 network 192.168.20.0 255.255.255.0
 default-router 192.168.20.1
ip dhcp pool ONEOONE
 network 192.168.101.0 255.255.255.0
 default-router 192.168.101.1
ip dhcp pool THIRTY
 network 192.168.30.0 255.255.255.0
 default-router 192.168.30.1
ip dhcp pool Wifi_Camera
ip dhcp pool fourty
 network 192.168.40.0 255.255.255.0
 default-router 192.168.40.1
ip dhcp pool FIFTY
 network 192.168.50.0 255.255.255.0
 default-router 192.168.50.1
ip dhcp pool WIN1
 host 192.168.10.76 255.255.255.0
 client-identifier 01fc.aa14.28be.c0
ip dhcp pool HA Server
 host 192.168.10.2 255.255.255.0
 client-identifier 01b8.27eb.8ee9.95
ip domain name ssmt.local
ip name-server 1.1.1.1
ip name-server 1.0.0.1
voice-card 0
license udi pid CISCO2921/K9 sn FGL171712X4
hw-module pvdm 0/0
username root privilege 15 password 0 password
username user secret 4 GK32328zogUw41aNsnIiZ9irs2rALsySwMouCKQYxus
redundancy
ip ssh version 2
crypto isakmp policy 100
 encr aes 256
 authentication pre-share
 group 20
 lifetime 3600
crypto isakmp client configuration group GroupVPN
 key groupkey
 pool VPNPool
crypto ipsec transform-set SetVPN esp-aes esp-sha-hmac
crypto dynamic-map DynamicVPN 100
 set transform-set SetVPN
 reverse-route
crypto map StaticMap client authentication list UserVPN
crypto map StaticMap isakmp authorization list GroupVPN
crypto map StaticMap client configuration address respond
crypto map StaticMap 20 ipsec-isakmp dynamic DynamicVPN
interface Loopback100
 description hairpin
 ip address 169.254.255.254 255.255.255.255
 ip nat inside
 ip virtual-reassembly in
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.100
 description -Internet-
 encapsulation dot1Q 100
 ip address 123.123.123.123 255.255.255.252
 no ip redirects
 ip nat outside
 ip nat enable
interface GigabitEthernet0/1
 no ip address
 ip pim dense-mode
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1.1
 encapsulation dot1Q 1 native
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.10
 ip address 192.168.10.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.30
 encapsulation dot1Q 30
 ip address 192.168.30.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.40
 encapsulation dot1Q 40
 ip address 192.168.40.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.50
 encapsulation dot1Q 50
 ip address 192.168.50.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/1.101
 encapsulation dot1Q 101
 ip address 192.168.101.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip cgmp
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 no ip address
 shutdown
 negotiation auto
ip local pool VPNPool 192.168.10.20 192.168.10.50
ip default-gateway 123.123.123.122
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat source static tcp 192.168.10.1 22 interface GigabitEthernet0/0.100 10122
ip nat inside source list NAT interface GigabitEthernet0/0.100 overload
ip nat inside source static tcp 192.168.30.3 8000 interface GigabitEthernet0/0.100 18000
ip nat inside source static udp 192.168.30.3 8000 interface GigabitEthernet0/0.100 18000
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0.100 27.32.231.217
ip access-list standard NAT
 permit 192.168.0.0 0.0.255.255
ip access-list extended NatPin
 permit ip 192.168.0.0 0.0.255.255 any
 permit ip 192.168.30.0 0.0.0.255 any
route-map NAT_PBR permit 10
 set interface Loopback100
control-plane
mgcp profile default
gatekeeper
 shutdown
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 privilege level 15
 login local
 transport input ssh
line vty 5 15
 login local
 transport input all
scheduler allocate 20000 1000
end
Hello
Try the attached changes:
Kind Regards
Paul
with the changes marked in bold, all internal networks should be able to access 192.168.30.3 by its public IP address:
version 15.1
hostname RRouter
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool ONE
ip dhcp pool TEN
ip dhcp pool TWENTY
ip dhcp pool THIRTY
ip dhcp pool fourty
ip dhcp pool FIFTY
ip dhcp pool WIN1
voice-card 0
hw-module pvdm 0/0
redundancy
ip ssh version 2
encr aes 256
group 20
lifetime 3600
key groupkey
pool VPNPool
reverse-route
description hairpin
ip nat inside
no ip address
shutdown
no ip address
duplex auto
speed auto
no ip redirects
ip nat outside
--> no ip nat enable
no ip address
ip pim dense-mode
ip nat inside
duplex auto
speed auto
ip pim dense-mode
--> ip nat outside
--> ip policy route-map PBR_NAT_RM
ip cgmp
ip pim dense-mode
--> ip nat outside
ip cgmp
ip pim dense-mode
--> ip nat outside
ip cgmp
ip pim dense-mode
--> ip nat outside
ip cgmp
ip pim dense-mode
--> ip nat outside
ip cgmp
ip pim dense-mode
--> ip nat outside
ip cgmp
ip pim dense-mode
--> ip nat outside
ip cgmp
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
negotiation auto
--> no ip default-gateway 123.123.123.122
no ip http server
ip dns server
--> ip nat inside source list NAT_ACL interface GigabitEthernet0/0.100 overload
--> ip nat inside source list NAT_HAIRPIN_ACL interface Loopback 100 overload
--> ip access-list extended NAT_ACL
--> deny ip 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255
--> deny ip 192.168.10.0 0.0.0.255 192.168.10.0 0.0.0.255
--> deny ip 192.168.20.0 0.0.0.255 192.168.20.0 0.0.0.255
--> deny ip 192.168.30.0 0.0.0.255 192.168.30.0 0.0.0.255
--> deny ip 192.168.40.0 0.0.0.255 192.168.40.0 0.0.0.255
--> deny ip 192.168.50.0 0.0.0.255 192.168.50.0 0.0.0.255
--> deny ip 192.168.101.0 0.0.0.255 192.168.101.0 0.0.0.255
--> permit 192.168.1.0 0.0.0.255 any
--> permit 192.168.10.0 0.0.0.255 any
--> permit 192.168.20.0 0.0.0.255 any
--> permit 192.168.30.0 0.0.0.255 any
--> permit 192.168.40.0 0.0.0.255 any
--> permit 192.168.50.0 0.0.0.255 any
--> permit 192.168.101.0 0.0.0.255 any
--> ip access-list extended NAT_HAIRPIN_ACL
--> permit ip 192.168.1.0 0.0.0.255 host 192.168.30.3
--> permit ip 192.168.10.0 0.0.0.255 host 192.168.30.3
--> permit ip 192.168.20.0 0.0.0.255 host 192.168.30.3
--> permit ip 192.168.30.0 0.0.0.255 host 192.168.30.3
--> permit ip 192.168.40.0 0.0.0.255 host 192.168.30.3
--> permit ip 192.168.50.0 0.0.0.255 host 192.168.30.3
--> permit ip 192.168.101.0 0.0.0.255 host 192.168.30.3
--> route-map PBR_NAT_RM permit 10
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
login local
transport input ssh
line vty 5 15
login local
transport input all
end
