iWAN Deployment
Can we terminate mpls and internet circuit on one DMVPN hub router? Customer is looking for attached high level design.
They have two separate internet circuit and two different layer 2 circuit. They want to terminate two circuit on one hub router.
I think this is the latest.
http://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Apr2017/CVD-IWANConfigurationFiles-APR17.pdf
TIA
Hitesh
Hitesh Vinzoda
Level 4
Level 4
Hello Dude,
Its immaterial that what you use as your underlay network for DMVPN. This is doable.
Hitesh
Thanks Hitesh, Did Cisco release the configuration guide for iWAN 2.2 ?
Mohammed
TIA
Hitesh
