IWAN PFRv3 Load Balancing
I am working on a 4 site IWAN - PFRv3 install.  This is currently in lab.  I thought I had it all working but when I started generating some traffic for testing I found that all traffic paths are using the same tunnel.  The domain master exist cli shows the inbalance.  Am I simply not generating enough to tip the load balance features.  I did read that the available bandwidth is the first criteria.  Ahead of explicitly stated path statements.  Bandwidth on the interfaces are the same at all points.   Thoughts?  Any help is appriceated.
CR1#sh domain IWAN master traffic-classes summary
APP - APPLICATION, TC-ID - TRAFFIC-CLASS-ID, APP-ID - APPLICATION-ID
SP - SERVICE PROVIDER, PC = PRIMARY CHANNEL ID,
BC - BACKUP CHANNEL ID, BR - BORDER, EXIT - WAN INTERFACE
UC - UNCONTROLLED, PE - PICK-EXIT, CN - CONTROLLED, UK - UNKNOWN
Dst-Site-Pfx      Dst-Site-Id       State DSCP      TC-ID APP-ID    APP           Current-Exit
10.10.40.0/24    10.1.127.5      CN    4[4]      2608  N/A       N/A  CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:1373)
10.10.40.0/24    10.1.127.5      CN    cs5[40]   2581  N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:1340)
10.10.40.0/24    10.1.127.5      CN    cs7[56]   2580  N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:1338)
10.10.40.0/24    10.1.127.5      CN    default[0 2564  N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:913)
10.10.25.5/32    10.1.127.7      CN    default[0 2284  N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:438)
10.10.25.6/32    10.1.127.7      CN    default[0 2279  N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:438)
10.10.40.5/32    10.1.127.5      CN    default[0 2255  N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:913)
10.10.40.6/32    10.1.127.5      CN    default[0 921   N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:913)
10.11.0.6/32     10.1.127.9      CN    default[0 2300  N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:440)
10.10.25.0/24    10.1.127.7      CN    4[4]      2609  N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:1375)
10.11.0.5/32     10.1.127.9      CN    default[0 2299  N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:440)
10.11.0.0/24     10.1.127.9      CN    4[4]      2583  N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:1344)
10.11.0.0/24     10.1.127.9      CN    default[0 301   N/A       N/A           CTLMPLS(0:0|0:0)/10.1.127.1/Tu100(Ch:440)
 Total Traffic Classes: 13 Site: 13  Internet: 0
CR1#sh domain IWAN master exits
  BR address: 10.1.127.1 | Name: Tunnel100 | type: external | Path: MPLS1 | path-id: 0 | PLR TCs: 0
      Egress capacity: 102400 Kbps | Egress BW: 17302 Kbps | Ideal:9369 Kbps | over: 7933 Kbps | Egress Utilization: 16 %
      DSCP: default[0]-Number of Traffic Classes[8]
      DSCP: 4[4]-Number of Traffic Classes[3]
      DSCP: cs5[40]-Number of Traffic Classes[1]
      DSCP: cs7[56]-Number of Traffic Classes[1]
  BR address: 10.1.127.2 | Name: Tunnel200 | type: external | Path: MPLS2 | path-id: 0 | PLR TCs: 0
      Egress capacity: 102400 Kbps | Egress BW: 1436 Kbps | Ideal:9369 Kbps | under: 7933 Kbps | Egress Utilization: 1 %
CR1#sh run | sec domain
domain IWAN
 vrf default
  border
   source-interface Loopback0
   master local
  master hub
   site-prefixes prefix-list DC01-SitePrefix
   monitor-interval 2 dscp af33
   monitor-interval 2 dscp cs4
   monitor-interval 2 dscp cs5
   monitor-interval 2 dscp ef
   load-balance advanced
    path-preference MPLS2 fallback MPLS1
   enterprise-prefix  prefix-list EntPrefix
   class VOICE sequence 10
    match dscp ef policy voice
    path-preference MPLS1 fallback MPLS2
   class SMB sequence 20
    match dscp default policy bulk-data
   class Background sequence 30
    match dscp cs1 policy best-effort
Hello.
You are right - that is the problem:
Channel Id: 1668  Dst Site-Id: 10.1.127.7  Link Name: MPLS2  DSCP: 4 [4] pfr-label: 0:0 | 0:0 [0x0] TCs: 0  BackupTCs: 0
  Channel Created: 00:04:24 ago
  Provisional State: Initiated and open
  Operational state: Not-Available(Channel in Initial state)
To troubleshoot you need to go to the BRs (Hub and branch) and collect:
  • show domain ... border channel
  • show domain ... border channel parent-route
This, for example, may be a routing issue, when RIB (on HubBR) for remote branch does not point into the tunnel or has [unexpectedly] multiple entries; or may be QoS issue.
PS: basic diagram with IP-addresses (including overlay ip-addresses) could be beneficial.
5 Replies 5
Hello.
You may run debugs for pdp process:
  • debug domain IWAN master pdp path-preference
  • debug domain IWAN master pdp path-selection
Also you may lower tunnel bandwidth to 20M and you won't need more traffic to observe the behaviour.
Could you also provide outputs for "show domain IWAN master traffic dscp 4" + "show domain IWAN master channel" ?
Attached debug and show outputs.
Thank you for your time and input on this.
Hello.
I was so focused on your reply from the other post I didnt see this reply.  Reposting the resolution here.
The Devil is in the details. Your reply helped me focus and discover the root cause, so thank you very much. I was only seeing RX in the Initial State. TX was Reachable. Not sure how that added up to me checking the routing config but it did. One of those 'you look are the config 100 times but still seem to miss what you missed' I have been through the CVD and many other references but you still miss things. This is my first real exposure to PfR (any version) and from what I have heard v3 is far easier the previous versions.
The root cause was that I missed a route-map on the second BR that tags all routes as the loopback / routerID IP.
router eigrp IWAN
address-family ipv4 unicast autonomous-system 1001
af-interface Tunnel200
summary-address 10.16.40.0 255.255.252.0
summary-address 10.18.0.0 255.255.252.0
hello-interval 20
hold-time 60
no next-hop-self
no split-horizon
exit-af-interface
af-interface GigabitEthernet0/0/0.3
passive-interface
exit-af-interface
af-interface GigabitEthernet0/0/0.4
passive-interface
exit-af-interface
af-interface GigabitEthernet0/0/0.5
passive-interface
exit-af-interface
topology base
##### missing corresponding route-map for distribution-list below ####
distribute-list route-map SET-TAG-ALL out Tunnel200
distribute-list route-map BLOCK-DMVPN1 in GigabitEthernet0/0/0.2
distribute-list route-map SET-TAG-DMVPN2 out GigabitEthernet0/0/0.2
exit-af-topology
network 10.18.0.0 0.0.0.255
network 10.18.1.0 0.0.0.255
network 10.18.2.0 0.0.0.255
network 10.18.3.0 0.0.0.255
network 10.31.126.0 0.0.0.255
network 10.31.127.2 0.0.0.0
eigrp router-id 10.31.127.2
exit-address-family
route-map BLOCK-DMVPN1 deny 10
match tag 10.31.127.1
route-map BLOCK-DMVPN1 permit 20
###### COMPLETELY MISSING route-map below #####
route-map SET-TAG-ALL permit 10
description tag all routes advertised through the tunnel
set tag 10.31.127.2
route-map LEAK-DMVPN2 permit 10
match ip address prefix-list LOCAL-ROUTES
set tag 10.31.127.2
route-map SET-TAG-DMVPN2 permit 10
match ip route-source DMVPN2-SPOKES
set tag 10.31.127.2
route-map SET-TAG-DMVPN2 permit 20
description advertise all other routes with no tag
I see in the 'show domain...channels' cmd that all of the tunnels over MPLS2 are provisional state as 'initiated and open' but the operational state is 'not-available'
Now to figure out why.
