Joining AP802 to 2125 WLC
Hi.
I'm having problem joining a AP802 access-point in a Cisco 887VAM-W router to a WLC2125 running 7.0.116.0. I get the following messages pasted below from the AP console. The AP connects to the WLC over a EZVpn tunnel with a ASA on the other end, and can't see any error messages there.
Any ideas?
%Error opening flash:/ap802-rcvk9w8-mx/info (File not found)cisco AP802GN-E-K9         (revision A0) with 98304K/32768K bytes of memory.
Processor board ID FCZ1546C6N5
Last reset from reload
LWAPP image version 7.0.112.74
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 64:00:F1:71:BA:BA
Part Number                          : 74-7519-02
PCA Assembly Number                  : 800-34495-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC15353ZJ1
Top Assembly Part Number             : 800-34363-01
Top Assembly Serial Number           : FCZ1546C6N5
Top Revision Number                  : A0
Product/Model Number                 : AP802GN-E-K9
% Please define a domain-name first.
Press RETURN to get started!
logging facility kern
% Invalid input detected at '^' marker.
*Mar  1 00:00:03.115: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 169 messages)
*Mar  1 00:00:04.147: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:03:06.139: %SYS-5-RESTART: System restarted --
Cisco IOS Software, AP802 Software (AP802-RCVK9W8-M), Version 12.4(23c)JA2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 13-Apr-11 12:32 by prod_rel_team
*Mar  1 00:03:06.155: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:03:06.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:03:18.235: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 172.18.7.99, mask 255.255.255.192, hostname AP6400.f171.baba
Translating "CISCO-CAPWAP-CONTROLLER.xxxx.local"...domain server (172.16.20.12)
Translating "CISCO-LWAPP-CONTROLLER.xxxxx.local"...domain server (172.16.20.12) [OK]
*Dec  5 02:29:20.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.20.10 peer_port: 5246
*Dec  5 02:29:20.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Dec  5 02:29:20.995: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.20.10 peer_port: 5246
*Dec  5 02:29:20.995: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.20.10
*Dec  5 02:29:20.995: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
examining image...
*Dec  5 02:29:25.995: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.20.10perform archive download capwap:/ap802 tar file
*Dec  5 02:29:26.011: %CAPWAP-5-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*Dec  5 02:29:26.307: %CAPWAP-5-CHANGED: CAPWAP changed state to IMAGE
*Dec  5 02:30:16.115: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.16.20.10:5246
*Dec  5 02:30:16.115: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Dec  5 02:30:16.115: %CAPWAP-3-ERRORLOG: capwap ifs:  read error or timeout
%Error opening flash:/update/info (File not found)
ERROR: Image is not a valid IOS image archive.
archive download: takes 52 seconds
*Dec  5 02:30:18.083: capwap_image_proc: problem extracting tar file
/Johan Christensson
5 Replies 5
Leo Laohoo
Can you please provide the output of "dir"?
Wow! That was quick!
Here is the dir of the AP flash:
    1  -rw-     3256320   Dec 4 2011 22:16:10 +01:00  ap802-rcvk9w8-tar.124-23c.JA2.tar
    2  -rw-     6645760   Dec 4 2011 22:16:54 +01:00  ap802-k9w7-tar.124-25d.JAX.tar
  163  drw-           0   Dec 5 2011 03:44:08 +01:00  update
    3  drw-           0   Dec 4 2011 22:17:18 +01:00  ap802-k9w7-mx.124-25d.JAX
  153  drw-           0   Dec 4 2011 22:21:34 +01:00  ap802-rcvk9w8-mx.124-23c.JA2
  159  -rw-         131   Dec 5 2011 03:42:12 +01:00  env_vars
  160  -rw-           5   Dec 4 2011 22:38:04 +01:00  private-config
  164  -rw-        6168   Dec 5 2011 03:43:52 +01:00  private-multiple-fs
  162  -rw-       14500   Dec 5 2011 03:28:12 +01:00  event.log
/Johan Christensson
Wow.  You've got some "junk" files.
1.  delete /f /r flash:ap802-rcvk9w8-tar.124-23c.JA2.tar
2.   delete /f /r flash:ap802-k9w7-tar.124-25d.JAX.tar
3.  delete /f /r flash:ap802-k9w7-tar.124-25d.JAX.tar
Reboot WLC
4.  clear capwap ap controller ip address
5.  capwap ap controller ip address
Thanks for your reply.
I deleted the files/folders that you suggested and rebooted the controller and issued the commands, but the result seems to be the same.
In the controller I see the access-point from time to time, where it has status Downloading. The Primary SW version is 7.0.112.74 where all the other access-points hve version 7.0.116.0. Don't know if that makes any difference...
/Johan Christensson
I think that I found the reason. In the release notes for the 7.0.116.0 software it says:
"The Cisco 2100 Series Controllers do not support AP801 and AP802 access points"
That seems realy strange that a WLC that I understand is targetet for the same customers/company size that bye the 880-series routers......
/Johan Christensson
