just finish my CCNA
chrnad_63
need some advice.I know it wont be easy to get a job straight away.I need practical experience.Any website you recommend to use as a stimulator?I am using NETSIM, but i need something like a NETSIM PRO.Any other suggestion would help.Thanks you.
Rick Morris
Level 6
Level 6
The cert is nice, but from what it sounds like you only have book knowledge. I will never take credit away from knowledge, but honestly it will not get you a job. You need experience and a lab will not provide that. You should look for a entry level position, help desk or something to jump in. The book provides the why, but it is not a standard. You will find that what you see in the field is not always what is being taught in the book. Nothing can top the field level experience, but take that along with the cert and it will help.
Also, it might help to buy a lab off of ebay and do some physical along with the configurations if you really want some true level experience.
I'm currently studying the ICND1 (part 1). I have read the book and done the questions should I buy a lab for this first book? It will give me the CCENT qualification, then if I do part 2 I get the CCNA.
