kindly help me to slove bgp query
sureshthakur
   We have two ASR directly connected through ibgp.On ASR A we have down stream BGP peer and we are receiving customer routing table on
ASR 'A' . Same customer having another peer on our B router with the same routing table. Now problem is the when I am adverting customer routing
table from router B to A after that we are advertising customer routing table to our upstream but  it's showing that routes is learned from router A.
Could you please help me to segregate this same routing table.
16 Replies 16
dukenuk96
Level 3
Level 3
you advertise client's routes from router A to your upstream and this upstream shows that routes are learned from router A. But what do you expect instead of this? If I did not understand you correctly please show full network diagram with interfaces, addresses, AS numbers and share full configurations.
   With the reference of attached network diagram, Router A and B which is ISP router belongs to AS38457 and router C is customer router belongs to AS45415. There is ibgp between ISP router A and B. we are catering to customer from router A google peering and router B internet bandwidth peering. We have IDEA upstream on router A ,when we do advertise customer routing table from router b to router A after and then to IDEA upstream then in BGP advertising routes it's learning from router A neighbor. I am expecting request comes from router b it should be deliver to that neighbor only.
 See when we do like routes receives from customer router c to A and then we do advertise to google peer and customer router C to Router B and then bharti upstream every thing is working fine.
router A config-
sh bgp neighbor 111.91.76.62 configuration
Fri Apr  8 15:01:29.850 GMT
 remote-as 45415                        []
 description "DW-PEER_VCPL-AS45415"     []
 graceful-restart                       []
 enforce-first-as                       []
 address-family IPv4 Unicast            []
  maximum-prefix 30000 75               []
  policy EBGP_IPV4_VASAI01_IMPORT in    []
  policy EBGP_GOOGLE_VASAI01_EXPORT out []
  remove-private-AS                     []
  soft-reconfiguration inbound always
route-policy EBGP_IPV4_VASAI01_IMPORT
  if destination in IPv4-Prefix-AS45415-Vasaicable then
    set local-preference 400
    set next-hop 111.91.76.62
    pass
  endif
end-policy
router B config-
RP/0/RSP0/CPU0:core02#sh bgp neighbor 111.91.76.254 configuration
Fri Apr  8 15:03:25.151 GMT
 remote-as 45415                      []
 description "VCPL_IBW-620Mbps"       []
 graceful-restart                     []
  default-originate                   []
  maximum-prefix 1000 75              []
  policy EBGP_VCPL_IMPORT in          []
  policy EBGP_VCPL_EXPORT out         []
  soft-reconfiguration inbound always []
RP/0/RSP0/CPU0:core02#sh rpl route-policy EBGP_VCPL_IMPORT
Fri Apr  8 15:03:36.335 GMT
  if destination in IPv4-VCPL then
    pass
  endif
end-policy
You do not want Customer C to use IDEA upstream either for inbound or outbound traffic, right?
No your not getting I want to use IDEA for customer but routes should be learn form router B
Customer peer which is on router A is only for Google routes. I don't want to mix bandwidth traffic in  that.
see router A already has customer routing table when I advertise customer routing table from B to A and advertise to IDEA that time i don't want to see the routes are learning from customer google peer IP.
  some more clarification, see a request comes from customer bandwidth link which is on router b to IDEA upstream so it should be deliver that customer peer only.
Here the problem is that ISP router A is receiving customer same routing table from customer router c which and ISP router b. When reverse traffic comes from IDEA that time it taking router A path to reach to router customer router C. It should take ISP router B path. I hope you got my point now
Seems now I understand - you want Internet traffic to go the following path C - B - A - IDEA and google traffic through C - A - google?
Yes, you absolutely close but forward not an issue and one more addition is there when internet reverse traffic come from Idea for router C the path should be IDEA- A - B and then customer router C.
This is place where BGP PATH attributes manipulation comes into play and PBR also can help. I can try to simulate your situation and share resulting configurations but it will be with different addresses and on classic IOS, while you have IOS-XR as it seems to me.
OK thank you and please do share resulting configuration.
IDEA and BHARTI are just simple internet providers and send you full view, right?
yes, IDEA and Bharti are upstream BGP internet peers.
actually router A and B are transit for customer C to reach to internet as well GOOGLE.
Traffic to GOOGLE goes through the path C - A - GOOGLE, so there is nothing to do.
C#traceroute 8.8.8.8 source 3.0.0.1 numeric
VRF info: (vrf in name/id, vrf out name/id)
1 111.91.76.61 1 msec 0 msec 0 msec
2 10.0.8.1 1 msec * 1 msec
Let's assume that IDEA and BHARTI upstream announce the same prefix for Internet 6.0.0.0/24 with same metrics (actually this should never) happen, but we need this for testing and simplicity. IDEA has IP address 6.0.0.1 and BHARTI has IP address 6.0.0.2. So we will check both of them to determine which path takes traffic to and from router C.
C#traceroute 6.0.0.1 source 3.0.0.1 numeric
1 111.91.76.61 6 msec 5 msec 6 msec
2 10.0.2.2 6 msec * 2 msec
C#traceroute 6.0.0.2 source 3.0.0.1 numeric
1 111.91.76.61 0 msec 0 msec 1 msec
2 10.0.2.2 1 msec 1 msec 0 msec
3 * *
C#ping 6.0.0.1 so
C#ping 6.0.0.1 source 3.0.0.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
C#ping 6.0.0.2 source 3.0.0.1
Success rate is 0 percent (0/2)
Here we see that "Internet" traffic from router C takes path C - A - IDEA, while we need C - B - A - IDEA.
Now we will modify BGP path attributes only on routers A and B, since they are under our control. I will make as little changes as possible to default BGP decision process to reduce overall network impact.
The easiest thing is to manipulate AS_PATH LENGTH attribute on router A - we will prepend our AS38457 once to all routes except google's when advertising to router C.
Now we have:
C#sh ip bgp
* 6.0.0.0/24 111.91.76.253 0 38457 3333 i
*> 111.91.76.61 0 38457 2222 i
Through router A.
ip prefix-list PL-google permit 8.8.8.0/24
route-map RM-prepend-once-inet permit 10
 match ip address prefix-list PL-google
route-map RM-prepend-once-inet permit 20
 set as-path prepend 38457
router bgp 38457
 neighbor 111.91.76.62 route-map RM-prepend-once-inet out
And after these chages:
C#ip bgp clear 111.91.76.61
C#sh ip bgp
* 6.0.0.0/24 111.91.76.61 0 38457 38457 2222 i
*> 111.91.76.253 0 38457 3333 i
*> 8.8.8.0/24 111.91.76.61 0 38457 22859 i
Return traffic from router C to internet changed it's direction to B. Also note, that google's route is not affected.
But now we have another problem - since route decisions are made hop-by-hop, internet traffic from router C goes through router BGP to BHARTI upstream:
1 111.91.76.253 5 msec 5 msec 0 msec
2 10.0.5.1 0 msec 0 msec 0 msec
3 *
1 111.91.76.253 1 msec 1 msec 0 msec
2 10.0.5.1 1 msec * 1 msec
So we need to make router B prefer path through router A but only for networks from router C. Here we can use PBR:
ip prefix-list PL-c-networks seq 5 permit 3.0.0.0/24
route-map RM-c-networks-via-A permit 10
 match ip address prefix-list PL-c-networks
 set ip next-hop 10.1.1.1
interface Ethernet0/1
 ip policy route-map RM-c-networks-via-A
And now let's check:
1 111.91.76.253 0 msec 4 msec 8 msec
2 10.1.1.1 0 msec 1 msec 0 msec
3 10.0.2.2 1 msec * 3 msec
1 111.91.76.253 5 msec 6 msec 3 msec
2 10.1.1.1 1 msec 0 msec 1 msec
3 10.0.2.2 1 msec 0 msec 1 msec
4 * * *
5 *
Nice, that's exact what we need. Also, good news - if e0/0 on A or B will fail, normal, PBR-less routing will work, I checked:
B#debug ip policy
Policy routing debugging is on
B#
*Apr 12 07:48:51.771: IP: s=3.0.0.1 (Ethernet0/1), d=6.0.0.1, len 100, FIB policy match
*Apr 12 07:48:51.771: IP: s=3.0.0.1 (Ethernet0/1), d=6.0.0.1, len 100, PBR Counted
*Apr 12 07:48:51.771: CEF-IP-POLICY: fib for addr 10.1.1.1 is Not Attached; Nexthop rejected
*Apr 12 07:48:51.771: IP: s=3.0.0.1 (Ethernet0/1), d=6.0.0.1, len 100, FIB policy rejected - normal forwarding
But interface may not fail, while IP connectivity could be lost and interface state is up/up - to avoid such situation you will need to write IP SLA rules - do it yourself, since I'm lazy ;)
At this point we corrected how traffic travels from C through network. And now we want traffic from IDEA to travel the same way IDEA - A - B - C, let's check:
IDEA#traceroute 3.0.0.1 source 4.0.0.1 numeric
1 10.0.2.1 5 msec 2 msec 5 msec
2 111.91.76.62 1 msec * 3 msec
IDEA - A - C, let's correct this by changing Local Preference path attribute on router B for networks announced from C. This gives the routers inside a single AS (A and B in our situation) a value that they can send per-route and advertise to all iBGP routers inside the AS, so that all routers in the AS agree about which router is the best exit point for packets destined for that prefix. By design, LocPrf can be set by routers as they receive eBGP routes by using an inbound route map (c) CCNP ROUTE :)
Now we see:
A>sh ip bgp
* i 3.0.0.0/24 111.91.76.254 0 100 0 45415 i
*> 111.91.76.62 0 0 45415 i
We need to set LocPrf for network 3.0.0.0/24 higher than 100 on B:
route-map RM-c-networks-set-LocPrf-150 permit 10
 set local-preference 150
router bgp 38457
 neighbor 111.91.76.254 route-map RM-c-networks-set-LocPrf-150 in
Check:
A#clear ip bgp 10.1.1.2
A#sh ip bgp
* i 3.0.0.0/24 111.91.76.254 0 150 0 45415 i
Still wrong way, because next-hop 111.91.76.254 is not reachable, which is checked before LocPrf. Add some cosmetic on B:
router bgp 38457
 neighbor 10.1.1.1 next-hop-self
Check again:
A#sh ip bgp
*>i 3.0.0.0/24 10.1.1.2 0 150 0 45415 i
* 111.91.76.62 0 0 45415 i
That's what we wanted to do, now check from IDEA's perspective:
IDEA#ping 3.0.0.1 source 4.0.0.1
1 10.0.2.1 5 msec 5 msec 5 msec
2 10.1.1.2 1 msec 0 msec 0 msec
3 111.91.76.254 1 msec * 2 msec
Good. Seems we've achieved what you wanted.
In conclusion - do not accept this solution as ready-to-use, since I do not know all your infrastructure and there may be better
implementations of the same task. If you administer such a network for a long time I would recommend to read, do all the labs and pass CCNP
ROUTE exam, it costs spending time and money, you will be more confident with such cases.
Good luck!
Thanks for your revert and support.
I have implemented PBR and it's working fine.Actually we can't achieve this by any BGP attribute.
Just because you did it wrong way :)
If you implemented it with PBR but without IP SLA, when IP connectivity will be lost, routing logic will not failover to redundant paths.
