Kingston Communications in UK
craig.bufton
Has any body got a samle config that i can use on a cisco 877 for connecting to there ADSL service. i cant seem to get connected with the useually settings in the UK. i am interest in the ATM0 settings and Dialer1 setup pvc etc.
many thanks
bjornarsb
Level 4
Level 4
Try this: (Kingston Comm)
Interface Type - PPPoA (RFC 2364)
VPI 1
VCI 50
Authentication Mode CHAP
Modulation Type G.DMT
Encapsulation Mode LLC (aal5snap)
interface Vlan1
ip nat inside
ip virtual-reassembly (default)
interface ATM0
no ip address
ip nat outside
no atm ilmi-keepalive
pvc 1/50
encapsulation aal5snap ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface Dialer0
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap
ip classless (default)
ip nat pool pool1 192.168.1.0 192.168.2.0 netmask 0.0.0.255
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
ip route 10.10.25.2 0.255.255.255 dialer 0
Bjornarsb
craig.bufton
ok thanks i will give that a try many thanks
OK, please rate if it works :)
BR,
Bjornarsb
Hi All!
I'm also having some grief with an 877 (in the UK - not Kingston but you may have similar issues). If you aren't getting the ATM interface up at all, try going to this URL:
ftp://ftp.cisco.com/pub/access/800
Download the 3.0.10 ADSL firmware. Copy it to flash, and rename to this name exactly:
adsl_alc_20190.bin
This got mine trained up fine - prior to this it appeared to be dead...
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
