08-30-2010 10:01 AM - edited 03-04-2019 09:36 AM
I have a LAN to LAN VPN tunnel established between a Cisco ASA 5505 and a Cisco 2811, but for some reason, I am unable to get SMTP communication between the two LAN's over the tunnel. Do I need to create a specific access rule for SMTP? The 2811's internal IP scheme is 10.4.167.X, and the ASA 5505,'s internal IP scheme is 192.168.1.0. I've attached the running-configs for both the ASA and the 2811. The tunnel establishes successfully, I can maps drives and replicate DNS data without any problems, but canot send email (SMTP) thru the tunnel. Any help would be greatly appreciated.
Solved! Go to Solution.
08-31-2010 11:34 AM
Did you remove the existing NAT statement before entering the new one? Also,
I noticed that the name of the route-map seems to be different (not
SDM_RMAP_1)
CISCO2811(config)#route-map SDM_RMAP_
CISCO2811(config-route-map)#match ip address 104
CISCO2811(config-route-map)#exit
NT
08-31-2010 12:27 PM
You're the MAN!!!!! Thank you soooooo much. That resolved it. I had mistyped the SDM_RMAP_1 as you pointed out.
Everything appears to be working now. Again, thank you for your efforts in helping me resolve this.
