l2tp/ipsec vpn tunnel between cisco routers
lishniy
Hi. I'm newbie with cisco. Tried connect cisco 1811 and cisco 881.
cisco 1811 as server config
no service pad
    service password-encryption
    hostname cisco-m1
    boot-start-marker
    boot-end-marker
    security authentication failure rate 5 log
    aaa new-model
    aaa authentication login default local
    aaa authentication ppp VPDN_AUTH local
    aaa session-id common
    no ip source-route
    ip cef
    ip auth-proxy max-nodata-conns 3
    ip admission max-nodata-conns 3
    no ip dhcp use vrf connected
    ip dhcp excluded-address 192.168.33.1 192.168.33.10
    ip dhcp pool LAN
       import all
       network 192.168.33.0 255.255.255.0
       default-router 192.168.33.1
       dns-server 192.168.33.1
    no ip bootp server
    ip domain name wizard
    ip name-server 8.8.8.8
    ip name-server 77.88.8.8
    ip name-server 1.1.1.1
    vpdn enable
    vpdn-group L2TP
    ! Default L2TP VPDN group
     accept-dialin
      protocol l2tp
      virtual-template 1
     no l2tp tunnel authentication
    username admin privilege 15 secret 5 $1$8PXC$3QykP9PmpxrrieYXH33Hz/
    username office privilege 15 password 7 06573E735B1D0C58
    ip ssh time-out 60
    ip ssh authentication-retries 2
    ip ssh version 2
    crypto isakmp policy 1
     encr 3des
     authentication pre-share
     group 2
     lifetime 3600
    crypto isakmp key SuperKolobok address 0.0.0.0 0.0.0.0
    crypto ipsec transform-set L2TP-Set esp-3des esp-sha-hmac
     mode transport
    crypto dynamic-map dyn-map 10
     set nat demux
     set transform-set L2TP-Set
    crypto map outside_map 65535 ipsec-isakmp dynamic dyn-map
    interface FastEthernet0/0
     description === Internet ===
     ip address dhcp
     no ip redirects
     no ip proxy-arp
     ip nat outside
     ip virtual-reassembly
     duplex auto
     speed auto
     no cdp enable
    interface FastEthernet0/1
     no ip address
     shutdown
     duplex auto
     speed auto
    interface FastEthernet0/0/0
    interface FastEthernet0/0/1
    interface FastEthernet0/0/2
    interface FastEthernet0/0/3
    interface Virtual-Template1
     ip unnumbered FastEthernet0/0
     peer default ip address pool my_pool
     ppp authentication ms-chap-v2 VPDN_AUTH
    interface Vlan1
     description === LAN ===
     ip address 192.168.33.1 255.255.255.0
     ip nat inside
    ip local pool my_pool 192.168.38.10 192.168.38.200
    ip forward-protocol nd
    ip route 0.0.0.0 0.0.0.0 dhcp
    no ip http server
    no ip http secure-server
    ip nat inside source list 15 interface FastEthernet0/0 overload
    ip dns server
    ip access-list extended FIREWALL
     permit tcp any any eq 22
    access-list 15 permit 192.168.33.0 0.0.0.255
    control-plane
    line con 0
    line aux 0
    line vty 0 4
     access-class 23 in
     exec-timeout 60 0
     privilege level 15
     logging synchronous
     transport input telnet ssh
    scheduler allocate 20000 1000
    end
I can connect from windows to this router.
And second client config
no service pad
    hostname cisco
    boot-start-marker
    boot-end-marker
    aaa new-model
    memory-size iomem 10
    no ip source-route
    ip dhcp excluded-address 192.168.81.1
    ip dhcp pool LAN
     import all
     network 192.168.81.0 255.255.255.0
     default-router 192.168.81.1
     dns-server 192.168.81.1
    ip cef
    no ip bootp server
    no ipv6 cef
    license udi pid CISCO881-SEC-K9 sn xxxxxx
    username admin privilege 15 secret 4 cJEHTWJcGi7nngW/tDdtmTd.aBJYqGTk5zlVP3d4Nbc
    ip ssh time-out 60
    ip ssh version 2
    pseudowire-class class1
     encapsulation l2tpv2
     ip local interface FastEthernet4
     encr 3des
     group 2
     lifetime 3600
    crypto isakmp key SuperKolobok address 192.168.30.37
     mode transport
     set peer 192.168.30.37
     no ip address
    interface FastEthernet1
     no ip address
    interface FastEthernet2
     no ip address
    interface FastEthernet3
     no ip address
     ip address dhcp
     no ip redirects
     no ip proxy-arp
     ip nat outside
     no ip virtual-reassembly in
     duplex auto
     speed auto
     no cdp enable
    interface Virtual-PPP1
     description -= VPN L2TP client =-
     ip address negotiated
     ip nat outside
     ppp authentication ms-chap-v2 callin
     ppp chap hostname office
     ppp chap password 7 06573E735B1D0C58
     ppp ipcp address accept
     no cdp enable
     pseudowire 192.168.30.37 1 pw-class class1
    interface Vlan1
     ip address 192.168.81.1 255.255.255.0
     ip nat inside
    no ip http server
    ip dns server
    ip nat inside source list 15 interface FastEthernet4 overload
    ip route 192.168.38.0 255.255.255.0 Virtual-PPP1
    access-list 15 permit 192.168.81.0 0.0.0.255
    control-plane
    line con 0
    line aux 0
    line vty 0 4
     access-class 23 in
     exec-timeout 60 0
     privilege level 15
     logging synchronous
    ntp update-calendar
    ntp server 0.pool.ntp.org
    ntp server ntp2.stratum2.ru
    end
And there is a problem. vpn doest't work
 Oct 30 08:21:44.852: PPP: Alloc Context [85E560DC]
    Oct 30 08:21:44.852: ppp5 PPP: Phase is ESTABLISHING
    Oct 30 08:21:44.852: Vp1 PPP: Using default call direction
    Oct 30 08:21:44.856: Vp1 PPP: Treating connection as a dedicated line
    Oct 30 08:21:44.856: Vp1 PPP: Session handle[2F000001] Session id[5]
    Oct 30 08:21:44.856: Vp1 LCP: Event[OPEN] State[Initial to Starting]
    Oct 30 08:21:44.856: Vp1 LCP: O CONFREQ [Starting] id 1 len 15
    Oct 30 08:21:44.856: Vp1 LCP:    AuthProto MS-CHAP-V2 (0x0305C22381)
    Oct 30 08:21:44.856: Vp1 LCP:    MagicNumber 0xF2CF7208 (0x0506F2CF7208)
    Oct 30 08:21:44.856: Vp1 LCP: Event[UP] State[Starting to REQsent]d
    Oct 30 08:21:46.852: Vp1 LCP: O CONFREQ [REQsent] id 2 len 15
    Oct 30 08:21:46.852: Vp1 LCP:    AuthProto MS-CHAP-V2 (0x0305C22381)
    Oct 30 08:21:46.852: Vp1 LCP:    MagicNumber 0xF2CF7208 (0x0506F2CF7208)
    Oct 30 08:21:46.852: Vp1 LCP: Event[Timeout+] State[REQsent to REQsent]
    Oct 30 08:21:46.852: Vp1 LCP: I CONFREQ [REQsent] id 1 len 15
    Oct 30 08:21:46.852: Vp1 LCP:    MagicNumber 0x225F17AF (0x0506225F17AF)
    Oct 30 08:21:46.852: Vp1 LCP: O CONFACK [REQsent] id 1 len 15
    Oct 30 08:21:46.852: Vp1 LCP: Event[Receive ConfReq+] State[REQsent to ACKsent]
    Oct 30 08:21:46.852: Vp1 LCP: I CONFACK [ACKsent] id 2 len 15
    Oct 30 08:21:46.852: Vp1 LCP: Event[Receive ConfAck] State[ACKsent to Open]
    Oct 30 08:21:46.856: Vp1 PPP: Queue CHAP code[1] id[1]
    Oct 30 08:21:46.884: Vp1 PPP: Phase is AUTHENTICATING, by both
    Oct 30 08:21:46.884: Vp1 MS-CHAP-V2: O CHALLENGE id 1 len 27 from "office"
    Oct 30 08:21:46.884: Vp1 CHAP: Redirect packet to Vp1
    Oct 30 08:21:46.884: Vp1 MS-CHAP-V2: I CHALLENGE id 1 len 29 from "cisco-m1"
    Oct 30 08:21:46.884: Vp1 LCP: State is Open
    Oct 30 08:21:46.888: Vp1 MS CHAP V2: Using hostname from interface CHAP
    Oct 30 08:21:46.888: Vp1 MS CHAP V2: Using password from interface CHAP
    Oct 30 08:21:46.888: Vp1 MS-CHAP-V2: O RESPONSE id 1 len 60 from "office"
    Oct 30 08:21:46.892: Vp1 MS-CHAP-V2: I RESPONSE id 1 len 62 from "cisco-m1"
    Oct 30 08:21:46.896: Vp1 MS-CHAP-V2: O FAILURE id 1 len 13 msg is "E=691 R=0"
    Oct 30 08:21:46.896: Vp1 PPP DISC: User failed MSCHAP-V2 authentication
    Oct 30 08:21:46.896: Vp1 PPP: Sending Acct Event[Down] id[D]
    Oct 30 08:21:46.896: PPP: NET STOP send to AAA.
    Oct 30 08:21:46.896: Vp1 LCP: Event[CLOSE] State[Open to Closing]
    Oct 30 08:21:46.896: Vp1 PPP: Phase is TERMINATIN
What i'm doing wrong?
what are you trying to accomplish ? Use both routers as VPDN servers ? Or establish a VPN between both routers ?
I think you are missing the access lists. Also, since your peers are both dynamic, delete the static peer. You probably still need dynamic DNS (DDNS), since both of your peers are dynamic.
Below are what I think should work (changes marked in bold):
no service pad
hostname cisco-m1
boot-start-marker
boot-end-marker
aaa new-model
no ip source-route
ip cef
ip dhcp pool LAN
import all
no ip bootp server
vpdn enable
vpdn-group L2TP
accept-dialin
protocol l2tp
virtual-template 1
ip ssh time-out 60
ip ssh version 2
encr 3des
group 2
lifetime 3600
mode transport
set nat demux
crypto map outside_map 10 ipsec-isakmp
match addess VPN_TRAFFIC
set peer cisco1.cisco.com dynamic
ip address dhcp
no ip redirects
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip http server
ip nat inside source list 101 interface FastEthernet0/0 overload
ip dns server
ip access-list extended VPN_TRAFFIC
permit 192.168.33.0 0.0.0.255 192.168.81.0 0.0.0.255
access-list 101 deny 192.168.33.0 0.0.0.255 192.168.81.0 0.0.0.255
access-list 101 permit 192.168.33.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 60 0
privilege level 15
logging synchronous
end
no service pad
hostname cisco
boot-start-marker
boot-end-marker
aaa new-model
no ip source-route
ip dhcp pool LAN
import all
ip cef
no ip bootp server
no ipv6 cef
ip ssh time-out 60
ip ssh version 2
encr 3des
group 2
lifetime 3600
mode transport
match address VPN_TRAFFIC
set peer cisco2.cisco.com dynamic
no ip address
no ip address
no ip address
no ip address
ip address dhcp
no ip redirects
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no cdp enable
ip nat outside
no cdp enable
interface Vlan1
ip nat inside
no ip http server
ip dns server
ip nat inside source list 101 interface FastEthernet4 overload
permit 192.168.81.0 0.0.0.255 192.168.33.0 0.0.0.255
access-list 101 deny 192.168.81.0 0.0.0.255 192.168.33.0 0.0.0.255
access-list 101 permit 192.168.81.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 60 0
privilege level 15
logging synchronous
ntp update-calendar
end
Hello
Try changing the transform sets to both tunnel mode and provide an access-list to match interesting traffic?
cisco-m1i
access-list 100 permit ip 192.168.33.0 0.0.0.255 192.168.81.0 0.0.0.255
 mode tunnel
match ip address 100
cisco
access-list 100 permit ip  192.168.81.0 0.0.0.255 192.168.33.0 0.0.0.255
 mode tunnel
Kind Regards
Paul
