L2TPv3 and Spanning-tree MST
fsebera
Level 4
Level 4
My L2TPv3 peering setup is using 2 Cisco 1841 routers and is working. Spanning-tree PVST is peering across the L2TPv3 tunnel, the head-end is the root for the 3 Vlans. Each Cisco 1841 router interfaces with a Cisco 3750 switch. The router & switch (at each end) interface via an 802.1q trunk.
Topology:
(Host1&2)__3750-1===trunk====1841-1--------L2TPv3-------1841-2=====trunk=====3750-2__(Host3&4)
Native Vlan 500
Host 1 Vlan 555
Host 2 Vlan 556
We want (need) to upgrade to spanning-tree MST but noticed during this change the MST domains remain isolated at each end. We suspect that since the Cisco 1841 routers do not support MST; these routers are creating a spanning-tree domain boundary.
Anyone know if this IS the case or have any suggestions to support MST across the L2TPv3 tunnel?
Thanks Frank
L2TPv3-1# sh l2tun tunn all
L2TP Tunnel Information Total tunnels 2 sessions 2
Tunnel id 259422696 is up, remote id is 3674041411, 1 active sessions
  Locally initiated tunnel
  Tunnel state is established, time since change 1d22h
  Tunnel transport is IP  (115)
  Remote tunnel name is L2TPv3-2
    Internet Address 192.168.0.5, port 0
  Local tunnel name is L2TPv3-1
    Internet Address 192.168.0.1, port 0
  L2TP class for tunnel is 555
  Counters, taking last clear into account:
    77553 packets sent, 116125 received
    5323208 bytes sent, 8269418 received
    Last clearing of counters never
  Counters, ignoring last clear:
  Control Ns 14, Nr 16792
  Local RWS 1024 (default), Remote RWS 1024
  Control channel Congestion Control is disabled
  Tunnel PMTU checking disabled
  Retransmission time 1, max 1 seconds
  Unsent queuesize 0, max 0
  Resend queuesize 0, max 2
  Total resends 2, ZLB ACKs sent 16791
  Total out-of-order dropped pkts 0
  Total out-of-order reorder pkts 0
  Total peer authentication failures 0
  Current no session pak queue check 0 of 5
  Retransmit time distribution: 0 1 1 0 0 0 0 0 0
  Control message authentication is disabled
Tunnel id 3905588394 is up, remote id is 3875190023, 1 active sessions
    Internet Address 192.168.0.6, port 0
    Internet Address 192.168.0.2, port 0
  L2TP class for tunnel is 556
    79998 packets sent, 113345 received
    5489237 bytes sent, 8070888 received
  Control Ns 15, Nr 16794
  Resend queuesize 0, max 3
L2TPv3-1#
L2TPv3-1# sh spanning-tree
No spanning tree instances exist.
3750-1# sh span mst
##### MST0    vlans mapped:   1-554,557-4094
Bridge        address 0013.8072.1a00  priority      4096  (4096 sysid 0)
Root          this switch for the CIST
Operational   hello time 2 , forward delay 15, max age 20, txholdcount 6
Configured    hello time 2 , forward delay 15, max age 20, max hops    20
Interface        Role Sts Cost      Prio.Nbr Type
Fa1/0/16         Desg BKN*200000    128.18   P2p Bound(PVST) *PVST_Inc
##### MST1    vlans mapped:   555
Bridge        address 0013.8072.1a00  priority      1     (0 sysid 1)
Root          this switch for MST1
##### MST2    vlans mapped:   556
Bridge        address 0013.8072.1a00  priority      16386 (16384 sysid 2)
Root          this switch for MST2
L2TPv3-2# sh l2tun tunn all
Tunnel id 3674041411 is up, remote id is 259422696, 1 active sessions
  Remotely initiated tunnel
  Remote tunnel name is L2TPv3-1
  Local tunnel name is L2TPv3-2
    116312 packets sent, 77684 received
    8282704 bytes sent, 5332116 received
  Control Ns 16818, Nr 14
  Resend queuesize 0, max 1
  Total resends 0, ZLB ACKs sent 12
  Retransmit time distribution: 0 0 0 0 0 0 0 0 0
Tunnel id 3875190023 is up, remote id is 3905588394, 1 active sessions
    113532 packets sent, 80129 received
    8084174 bytes sent, 5498145 received
  Control Ns 16820, Nr 15
L2TPv3-2#
L2TPv3-2# sh spanning-tree
3750-2# sh span mst
Bridge        address 000f.2325.a700  priority      0     (0 sysid 0)
Fa1/0/13         Desg FWD 200000    128.15   P2p Bound(PVST)
Fa1/0/14         Desg FWD 200000    128.16   P2p
Fa1/0/15         Desg FWD 200000    128.17   P2p
Fa1/0/17         Desg FWD 200000    128.19   P2p
Fa1/0/21         Desg FWD 200000    128.23   P2p
Bridge        address 000f.2325.a700  priority      4097  (4096 sysid 1)
Bridge        address 000f.2325.a700  priority      8194  (8192 sysid 2)
16 Replies 16
Why cant we/you just use the physical interfaces to xconnect across instead of sub interfaces? (if it doesn't work) You could just have a normal trunk end to end between the switches? What is the actual requirement here for the sub-interfaces?
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hi Bilal,
You are correct! The truth is . . . . . . we (I) didn't know what we (I) were doing. :(
Based on your help, all is now configured PROPERLY and working as designed.
Thank you sir!!!
BTW, 1841 routers still running on IOS 15.1.
All the best!!!
Frank
