L2TPv3 tunnel between Cisco 2901's
earsenov1
We're trying to form an encrypted IPsec/L2TPv3 tunnel between two 2901 routers running IOS 15.4+.  When we try to connect, we can see that the IPsec tunnel is up and that the xconnect session is up but no L2 traffic is traversing the tunnel.  We are also able to ping each others public IP addresses.
The end systems which need to communicate through the tunnel are located on VLAN167 on RouterA and on Gi0/1 on RouterB
(Note: Actual IP addresses have been replaced in the configs below.)
ROUTER A CONFIGURATION:
version 15.4
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime localtime show-timezone
service password-encryption
service sequence-numbers
hostname ROUTER_A
boot-start-marker
boot-end-marker
logging buffered 10000000
no logging console
no logging monitor
no ip bootp server
no ip domain lookup
ip domain name domaina.com
ip cef
l2tp-class l2tp-defaults
 retransmit initial retries 30
 cookie size 8
no ipv6 cef
cts logging verbose
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package datak9
vtp mode transparent
redundancy
vlan 2
 name Test
vlan 167
 name L2TPv3
pseudowire-class l2tpv3
 encapsulation l2tpv3
 protocol none
 ip local interface GigabitEthernet0/0
crypto isakmp policy 100
 encr 3des
 authentication pre-share
 group 2
crypto isakmp key <CRYPTO KEY HERE> address <ROUTER B PUBLIC IP>
crypto ipsec transform-set ROUTERB esp-3des esp-sha-hmac
 mode tunnel
crypto map ROUTERB 100 ipsec-isakmp
 set peer <ROUTER B PUBLIC IP>
 set transform-set ROUTERB
 match address 100
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 description OUTSIDE
 ip address <ROUTER A PUBLIC IP>
 ip virtual-reassembly in
 duplex auto
 speed auto
 crypto map ROUTERB
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 description SWITCH UPLINK
 switchport trunk allowed vlan 1,2,167,1002-1005
 switchport mode trunk
 no ip address
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 no ip address
interface GigabitEthernet0/1/4
 no ip address
interface GigabitEthernet0/1/5
 no ip address
interface GigabitEthernet0/1/6
 no ip address
interface GigabitEthernet0/1/7
 no ip address
interface Vlan1
 no ip address
interface Vlan2
 description Test
 ip address 192.168.0.1 255.255.255.0
interface Vlan167
 description L2TPv3
 no ip address
 xconnect <ROUTER B PUBLIC IP> 1 encapsulation l2tpv3 manual pw-class l2tpv3
  l2tp id 100 200
  l2tp cookie local 4 100
  l2tp cookie remote 4 200
  l2tp hello l2tp-defaults
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 <DEFAULT GATEWAY HERE>
access-list 100 permit ip host <ROUTER A PUBLIC IP> host <ROUTER B PUBLIC IP>
ROUTER B CONFIGURATION:
version 15.4
hostname ROUTER_B
boot-start-marker
boot-end-marker
default-router <ROUTER B PUBLIC IP>
no ip bootp server
ip domain name domainb.com
ip cef
cookie size 8
no ipv6 cef
cts logging verbose
redundancy
no cdp run
ip ssh time-out 90
ip ssh authentication-retries 2
protocol none
ip local interface Dialer0
encr 3des
group 2
crypto isakmp key <CRYPTO KEY HERE> address <ROUTER A PUBLIC IP>
crypto ipsec transform-set ROUTERA esp-3des esp-sha-hmac
mode tunnel
crypto map ROUTERA 100 ipsec-isakmp
set peer <ROUTER A PUBLIC IP>
set transform-set ROUTERA
match address 100
no ip address
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no ip address
duplex auto
speed auto
xconnect <ROUTER A PUBLIC IP> 1 encapsulation l2tpv3 manual pw-class l2tpv3
  l2tp id 200 100
  l2tp cookie local 4 200
  l2tp cookie remote 4 100
interface Dialer0
ip address negotiated
ip mtu 1460
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1420
dialer pool 1
dialer-group 1
ppp chap hostname <USERNAME HERE>
ppp chap password 0 <PASSWORD HERE>
crypto map ROUTERA
no ip http server
no ip nat service sip udp port 5060
ip nat inside source list NAT interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended NAT
permit ip 192.168.0.0 0.0.0.255 any
permit ip host 0.0.0.0 any
access-list 1 permit <ROUTER A PUBLIC IP>
access-list 1 permit <ROUTER B PUBLIC IP>
access-list 100 permit ip host <ROUTER B PUBLIC IP> host <ROUTER A PUBLIC IP>
Philip D'Ath
xconnect usually needs to be done on routed ports, not switch ports.  There are some exceptions, but don't get down that path unless you want complications.
So on router 'A', plug gig0/1 into whatever vlan you wanted connected, and do the xconnect on that interface.
Philip D'Ath
You're correct!  The connection works after I moved the xconnect to Gi0/1.
It's interesting to note that this actually works if both ends setup their xconnects on switch port SVI's.
xconnect on a routed port (like Gig0/1) encapsulates the dot1q tag - so it can be a full 802.1q trunk.
When you do it on a vlan it doesn't encapsulate the dot1q tag.
Rohit Patil
LAN1<----->Router1<+++WAN++> Router2<====portchannel==>LAN2
does l2tpv3 supports from port channel interface of one side and physical interface on other side or port channel on both sides.
in above example if i have to establish L2 tunnel over the WAN between LAN1 and LAN2 then will that work?
