Multiple sub interfaces with Native vlan's?
jroy777
Sorry, I am reposting because I want the community to see this because where I previously posted, the thread shows resolved already.
I have an ASR 10g interface that is connected to a native vlan1 in a HP switching fabric (8 switches) for databases (inside for ASA), now I want to create a sub interface on that same 10g interface to another set of switches that are also on a separate switch fabric (4 switches) app/web servers dmz on ASA). Currently they talk to each only thru ASA. since both sets of switches are vlan1, how would I do this? The other side of ASR goes to AWS Direct connect environment and we need to move data between Data Center and AWS.
balaji.bandi
Post some diagram here to understand, how is ASA configured in Transparent or routed mode ?
high level you can create same way other sub interface and make sure your Layer 2 connected to right
BB
Giuseppe Larosa
Hello @jroy777 ,
each subinterface must use a different encapsulation , a different VLAN ID  and only one can use the native keyword on a single main interface.
So you need to see if you have another physical interface that you can use the restrictions above apply to subinterfaces of a single main interface not to subifs of different physical interfaces.
Another option is to have the second block of switches mapped to a different VLAN ID on the first block of HP switches using an access link ( no trunk mode  vlan 1 on second block side vlan x on HP switch side).  This way you could use a subinterface in vlan x on a single main 10GE interface on the ASR.
Hope to help
Giuseppe
