L2TPv3 tunneling xconnect through WAN
sachazufferey
hi guys,
I'm depressed, I can't get a working tunnel... I've tested everything I can, read docs, posts, etc... but it doesn't work.
I need to extend my Vlan105 from the HQ to a remote site.
Here is my setup :
PC [Fa] <---> [Gi] Cisco 2960-X [Gi24] <---> [Fa2] Cisco 886 [Dia0] <---> [[[WAN]]] <---> [Dia0] Cisco 886 [Fa2] <---> [Gi24] Cisco 2960-X [Gi] <---> [Fa] PC
And the config :
R1
pseudowire-class MYCLASS1
 encapsulation l2tpv3
 ip local interface Dialer0
interface FastEthernet2
 switchport access vlan 105
 no ip address
 xconnect 200.10.40.213 100 encapsulation l2tpv3 pw-class MYCLASS1
interface Vlan105
 ip address 10.10.10.100 255.255.240.0
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
interface Dialer0
 ip address negotiated
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp authentication chap callin
 ppp chap hostname 1234@domain.com
 ppp chap password 7 1234
 ppp pap refuse
 no cdp enable
R2
 no ip address
 xconnect 40.20.40.20 100 encapsulation l2tpv3 pw-class MYCLASS1
interface Vlan105
 ip address 10.10.10.200 255.255.240.0
 ip nat inside
interface Dialer0
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 crypto map vpn-dpm -------------------------->>>>>> I have a VPN too on this router, I tried to remove it but the problem is the same.
The tunnel is "established" but I can't ping from side-to-side BUT when I try "sh cdp neighbors" I see the switch from the other side...
ADSL_Centrale#sh l2tun
L2TP Tunnel and Session Information Total tunnels 1 sessions 1
LocTunID   RemTunID   Remote Name   State  Remote Address  Sessn L2TP Class/
                                                           Count VPDN Group
2998600478 552634819  R2 est    200.10.40.213 1     l2tp_default_cl
LocID      RemID      TunID      Username, Intf/      State  Last Chg Uniq ID
                                 Vcid, Circuit
2226540584 1855064800 2998600478 100, Fa2             est    14:44:21 5
Please help me to find a solution to this, thanks in advance for your help.
Have a nice day.
Sacha
9 Replies 9
minhda
Please post the interfaces configuration on switches at both ends.
Minh
Switch HQ (R1 side) :
interface GigabitEthernet1/0/24
 description *** Link to router ***
 switchport mode access
 spanning-tree bpdufilter enable
Switch Remote (R2 side) :
interface FastEthernet0/30
Thanks for your help!
Thanks. Please show spanning vlan 105 on the switches.
And does the ping work between pc & router at per site?
Yup it works...
SP for remote site :
VLAN0105
  Spanning tree enabled protocol rstp
  Root ID    Priority    24681
             Address     001e.f70d.f080
             Cost        12
             Port        28 (GigabitEthernet0/4)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32873  (priority 32768 sys-id-ext 105)
             Address     0023.344a.0980
             Aging Time 300
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/1               Desg FWD 4         128.1    P2p
Gi0/4               Root FWD 4         128.28   P2p
Fa0/30              Desg FWD 19        128.34   P2p Peer(STP)
Thanks for the outputs. How about spanning tree on other site?
Please also post the details show of l2tpv3 tunnels.
Same result on the other side...
Thanks.
Thanks.
Maurizio Roggia
Hi, did you find where was the problem? I'm hitting the same strange behavior.
make new post share it here in community
