L2VPN | Traffic Not Flowing After Moving To 9006 on new Local Handoff
TrivialPants
Hi All,
I have recently moved some circuits off of an xconnect to xconnect (remote and local) peers are both using the xconnect syntax for IOS XE.
The remote ends are still using IOS XE.
The new local side is a IOS XR device (ASR 9K) with 64 Bit 7.5.2 code. I have a bundle which I am using to hand-off to another router which has layer 3 interfaces on it. The xconnects are working fine in that they are established, and show 'UP', but for a select number of them, I cannot get two-way traffic to establish.
This may be a bit of a vague question, so I will continue to add in more details and provide some sanitized configuration if that helps.
However, I just wanted to see if anyone has run into this sort of issue and what you have done, anecdotally, to fix it.
Thanks!
neskemiquel
Thank you for sharing the information.
LA Fitness Employee Portal
