CSR 1000v Unable to License
KEVIN STEWART
I'm trying to bring up an evaluation of the CSR 1000v.  I have the license and the router, but when you try to follow the CSL steps there is a command to enable the license the command is missing for the install.  Using version 17.2.1r.
The only command available is the "license smart" not license install
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/b_CSR1000v_Configuration_Guide/b_CSR1000v_Configuration_Guide_chapter_01000.html
KEVIN STEWART
Ok.. so I was able to figure out that version 16.10 and above can only do smart licensing.. the issue now is it appears there is no way to get a smart license eval for version 17.2.1r to work as there doesn't appear to be a way to get an eval license moved to smart licensing..
There was a similar post here:
https://community.cisco.com/t5/routing/license-install-command-not-available-in-my-csr1000v-16-10/td-p/3763512
BrianSekleckiGE
Thanks.  Were you able to obtain an evaluation license from a Cisco Reseller? I assume that is what they want you to do, for example, if one wants to evaluate AX_5G or Appx_5G?  It is important to be able to get a evaluation to make R&D lab testing to validate the product.
