My names Terry, I'm a bit new here and new to Cisco ACI.
Wanted to ask a question about L3Out within the Logical Node Profiles
I have ipsec tunnel between 2 palos that are connected to my fabric. (before my time )
The Palos are connected to two BL's with a secondary ip address configured (HSRP) on each side.
I wanted to create a new tunnel on the same palos but with a different interface, Im assuming I will need to create a new logical node and attache the leaf switches.
Will I need to assign a new vlan ? and if so , will I need create a SVI for that vlan on the switch?
Also how does the routing work between the two BL at each side (Pod1 and Pod2). i see some tunnels on the arp entries but how are they created
This might be very messy and hard to understand but I sincerely appreciate any help that you can provide with this
God Bless
Terry
