Router 4331 with ZBF zone based firewall - VPN tunnel not working
Mina Tawfik
Kindly, we need your help.
We are testing on a router R2 some security ideas to secure the environment.
I hit a wall and need second help with the configuration.
First, here is the design ideas:
  • R2 is connected to internet connection from with a static public IP.
  • I use zone-based firewall ZBF and created the following:
    • Private zone which will be the Melbourne Office local network
      • This is vlan10 with 10.10.10.0 255.255.255.0.
    • Internet zone which is the internet connection.
    • Paired the 2 zones together with policy.
      • Allowed http, https, dns, icmp, and ssh.
  • A SW connected to R2; A laptop connected to the SW.
    • Laptop is on port 1 on the sw.
    • Router is on port 26 on the sw.
    • The SW is configured as trunk. No other configuration. SW is working fine without any issues
  • DHCP is on the router.
  • Uses isakmp to create a site-to-site VPN tunnel with Dom internal home network.
    • This is where the problem is right now.
The internal laptop is getting a correct IP from DHCP on the router. We can browse the internet without any issues.
Now, the issue here is the tunnel is up, but Dom’s home computer cannot communicate with the laptop here. No ping, or cannot open shared folder, and so on.
It looks like that the traffic from the VPN is not routed to the internal network. I tried to configure as in the config file below. The configuration should allow the traffic from the vpn tunnel to the internal network. Somehow, I failed to do that.
Can you take a look at the attached config file? I removed all the password from the file for security reasons.
Let me know your thoughts and recommendations.
Config file on R2:
no platform punt-keepalive disable-kernel-core
hostname ci_secondary
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 -----------------
enable password -----------------
no aaa new-model
ip name-server ----------------- ----------------- ----------------- ----------------- ----------------- -----------------
ip domain name ci.local
ip dhcp pool vlan10
 network 10.10.10.0 255.255.255.0
 default-router 10.10.10.1
 dns-server -----------------
subscriber templating
vpdn enable
vpdn-group 1
vpdn-group pppoe
username mina privilege 15 password 0 -----------------
username dominic privilege 0 secret 5 -----------------
redundancy
 mode none
vlan internal allocation policy ascending
class-map type inspect match-any priv-internet-class
 match protocol http
 match protocol https
 match protocol dns
 match protocol icmp
 match protocol ssh
policy-map type inspect priv-internet-policy
 class type inspect priv-internet-class
  inspect
 class class-default
  drop
zone security private
zone security internet
zone-pair security priv-internet-zone source private destination internet
 service-policy type inspect priv-internet-policy
class-map type inspect match-any DHCP-ALLOW
 match protocol udp
 match access-group name ALLOW-DHCP
 class type inspect DHCP-ALLOW
  pass
  inspect
 class class-default
  drop
ip access-list extended ALLOW-DHCP
 permit udp any any eq 67
 permit udp any any eq 68
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
 lifetime 28800
crypto isakmp key ----------------- address -----------------
crypto isakmp keepalive 180 periodic
crypto ipsec transform-set TS esp-3des esp-md5-hmac
 mode tunnel
crypto map CMAP 70 ipsec-isakmp
 set peer -----------------
 set transform-set TS
 match address DOM-VPN-TRAFFIC
interface GigabitEthernet0/0/0
 description Internet SecondaryWAN
 ip address ----------------- 255.255.255.254
 ip nat outside
 no shutdown
 zone-member security internet
 negotiation auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
 crypto map CMAP
interface GigabitEthernet0/0/1
 description SecondaryLAN
 no ip address
 ip nat inside
 zone-member security private
 no shutdown
 negotiation auto
interface GigabitEthernet0/0/1.10
 description vlan10 Melbourne office LAN network for internet
 encapsulation dot1Q 10
 ip address 10.10.10.1 255.255.255.0
 ip nat inside
 no shutdown
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
ip forward-protocol nd
ip dns server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 -----------------
ip ssh version 2
ip access-list extended DOM-VPN-TRAFFIC
 permit ip 10.10.10.0 0.0.0.255 192.168.70.0 0.0.0.255
 permit ip 10.10.10.0 0.0.0.255 192.168.71.0 0.0.0.255
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip nat inside source route-map NONAT interface GigabitEthernet0/0/0 overload
ip nat inside source list DOM-VPN-TRAFFIC interface GigabitEthernet0/0/0 overload
route-map NONAT permit 10
 match ip address DOM-VPN-TRAFFIC
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
access-list DOM-VPN-TRAFFIC permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map SWITCHVOX permit 10
 match ip address 110
control-plane
! To enable ssh access locally to the router.
crypto key generate rsa general-keys modulus 2048
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 access-class 1 in
 exec-timeout 60 0
 login local
 transport input ssh
line vty 5 15
 access-class 1 in
 login local
end
Hello @Mina Tawfik ,
remove the line
using:
conf t
no ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
because this is causing the NAT issue with VPN traffic . It it the route-map NONAT that use ACL 1 in the second block
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
the VPN traffic is likely NATTED with current config.
You need to change the route-map NONAT in the following manner:
route-map NONAT deny 10
route-map NONAT permit 20
match ip address 1
You need also to remove the line:
no ip nat inside source list DOM-VPN-TRAFFIC interface GigabitEthernet0/0/0 overload
 in global config
Edit:
I assume that the correct config of the named ACL is
Hope to help
Giuseppe
Hi Giuseppe,
I did that and still not working. Here is the config file:
hostname -----------------
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip domain name -----------------
ip dhcp pool vlan10
vpdn enable
vpdn-group 1
vpdn-group pppoe
license udi pid ISR4331/K9 sn FDO22381VB1
redundancy
mode none
match protocol http
match protocol dns
match protocol icmp
match protocol ssh
inspect
class class-default
drop
match protocol udp
pass
inspect
class class-default
drop
encr 3des
hash md5
group 2
lifetime 28800
mode tunnel
ip address ----------------- -----------------
ip nat outside
no shutdown
negotiation auto
crypto map CMAP
no ip address
ip nat inside
no shutdown
negotiation auto
description vlan10 -----------------t
ip nat inside
no shutdown
ip dns server
ip ssh version 2
match ip address 1
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 1 in
exec-timeout 60 0
login local
transport input ssh
line vty 5 15
access-class 1 in
login local
end
And here are the logs from the router once we tried the VPN connection:
*Mar 8 00:03:51.691: ISAKMP: (1001):set new node 3787667595 to QM_IDLE
*Mar 8 00:03:51.691: ISAKMP-PAK: (1001):sending packet to ----------------- my_port 500 peer_port 500 (R) QM_IDLE
*Mar 8 00:03:51.691: ISAKMP: (1001):Sending an IKE IPv4 Packet.
*Mar 8 00:03:51.691: ISAKMP: (1001):purging node 3787667595
*Mar 8 00:03:51.691: ISAKMP: (1001):Input = IKE_MESG_FROM_TIMER, IKE_TIMER_IM_ALIVE
*Mar 8 00:03:51.691: ISAKMP: (1001):Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLETE
*Mar 8 00:03:51.704: ISAKMP-PAK: (1001):received packet from ----------------- dport 500 sport 500 Global (R) QM_IDLE
*Mar 8 00:03:51.704: ISAKMP: (1001):set new node 464899042 to QM_IDLE
*Mar 8 00:03:51.704: ISAKMP: (1001):processing HASH payload. message ID = 464899042
*Mar 8 00:03:51.704: ISAKMP: (1001):deleting node 464899042 error FALSE reason "Informational (in) state 1"
*Mar 8 00:03:51.704: ISAKMP: (1001):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
*Mar 8 00:03:51.704: ISAKMP: (1001):Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLETE
*Mar 8 00:04:41.704: ISAKMP: (1001):purging node 464899042
So, the VPN connection is up. Still I cannot get the traffic between the 2 local subnets 192.168.70.x and 10.10.10.x
remove the line
using:
conf t
Hope to help
Giuseppe
Hi Giuseppe,
Looks like your trick solved the issue. I could ping the external router. Also, on the other side of the vpn tunnel, the user can ping the internet router here.
We could not ping the computers on both sides for some reason. But at least for now, the traffic is coming through the tunnel and exempted from NAT.
I will do more testing to troubleshoot why the computers cannot see the shared folders on each other yet.
Thank you so much mate for all the help.
you need to add new Zone pair
Self zone to internet zone (and reverse) allow (not inspect) the UDP 500 and 4500 traffic
MHM
