Lab route reflector with VRF
aw75635
Hello.
I am trying to set up al lab with route reflector and vrf-s. I have managed to set up the route reflectors and clients. All looks fine. Routes are being propagated.
The issue is that from DMZ router, using the interface assigned to
vrf 14000_custa_access
I cannot ping the interface assigned to
on Edge router.
If I run
sh ip route vrf 14000_custa_access
I can see the routes on both routers
DC01-DMZ-R01#sh ip route vrf 14000_custa_access
Routing Table: 14000_custa_access
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
192.168.50.0/32 is subnetted, 1 subnets
B 192.168.50.1 [200/0] via 15.15.15.15, 00:16:53
192.168.51.0/32 is subnetted, 1 subnets
C 192.168.51.1 is directly connected, Loopback1
192.168.52.0/32 is subnetted, 1 subnets
B 192.168.52.1 [200/0] via 11.11.11.11, 00:16:53
DC01-DMZ-R01#
If I run
sh ip bgp vpnv4 vrf 14000_custa_access
I see the information as well
DC01-DMZ-R01#sh ip bgp vpnv4 vrf 14000_custa_access
BGP table version is 6, local router ID is 13.13.13.13
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 14000:14000 (default for vrf 14000_custa_access)
* i 192.168.50.1/32 15.15.15.15 0 100 0 ?
*>i 15.15.15.15 0 100 0 ?
*> 192.168.51.1/32 0.0.0.0 0 32768 ?
* i 192.168.52.1/32 11.11.11.11 0 100 0 ?
*>i 11.11.11.11 0 100 0 ?
Doing a
debug ip icmp
debug ip packet detail
I see that there is no valid path to 192.168.50.1
What exactly am I missing. Attached config and picture of the setup
Thank you in advance.
You need MPLS, why ? because of VPNv4.
the global is using to establish BGP Peer
the Peer when receive packet for VRF destination in global interface the Peer drop packet.
instead using MPLS make router not depend on RIB instead it use MPLS label to forward traffic to right VRF.
8 Replies 8
I check the topology, can you more elaborate? can you right subnet and LO you use in your attach topology ?
Hello
got to clarify are you ping the vrf and not the GRT
ping vrf 14000_custa_access xxxxxx
Kind Regards
Paul
Hello
Correct, I ping with the VRF
DC01-DMZ-R01#ping vrf 14000_custa_access 192.168.50.1
Sending 5, 100-byte ICMP Echos to 192.168.50.1, timeout is 2 seconds:
DC01-DMZ-R01#ping vrf 14000_custa_access 192.168.50.1 source lo1
Packet sent with a source address of 192.168.51.1
Best regards
aw75635
I use OSPF to establish communication between BGP nodes. Using network 172.20.1.0/24
The switch has the ports configured as trunk.
Loopback interfaces on routers are used to establish neighborships between bgp reflectors and clients
Is there something specific you would like to know?
Best regards!
Hello. Yes it does work with mpls.  Thank you!
So MPLS is a MUST when using VPNV4
Thank you!
You are so so welcome
aw75635
I am using GNS3 for my LAB
