Lacp Bandwidth command on SG550 switch
Yasmeen
 Anyone share me the bandwidth checking commands on SG550 switch for LACp configuration.
I have configured LACp on SG550 switch for gi 1/0/1-1/0/2 ports,
I need to know the total bandwidth size of that po 1 port
what is the command to check total bandwidth
under Port Management > Link Aggregation > LAG Settings, check for 'Operational LAG Speed' (page 152 of the attached admin guide)...
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/admin_guide/AG_Tesla_350_550.pdf
Deepak Kumar
I hope it will help you:
SW#sho interfaces port-channel 1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 5008.ac75.xxxx (bia 5008.ac75.xxxx)
Description: SERVER
MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 3/255
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
